Milling 243 heads w/ nitrous???
Old 12-04-2009, 10:23 AM
nmcqueen469's Avatar
Default Milling 243 heads w/ nitrous???
I'm having a set of 243 heads worked over this winter. My plan is to have them milled .030" and use stock .051" gaskets. Should put my CR around 11.2:1.
I've been toying with the idea of spraying the car, but I want to know if my deck height will be too thin to spray.
What is the deck height limit when using nitrous? When do I need to go from bolts to studs?
Educate me please...
Old 12-04-2009, 01:38 PM
SS1875's Avatar
I'm in the same boat....but so far no one around town has said anything other than to spray the hell out of it. Will see I guess.
Old 12-04-2009, 01:51 PM
02*C5's Avatar
N2O can be used with compression ratios as low as 9.5:1 and as high as 15:1 its all about the set up. What you have to make sure is that you are using the correct equipment. Like ARP Studs/bolts. Also that your fuel is correct and you are running the correct timing. Many cars have milled .030 and are using N2O.
Good Luck
Old 12-04-2009, 02:31 PM
Yeah, that kinda seems like a Ft. Wayne thing haha. I've gotten some decent feedback on ls1gto since I'm a n00b when it comes to spray. Any bites on your car yet?
Good Luck
Thanks for the info. I'm going with ARP bolts, 42# injectors, and will be tuning with HP Tuners. Haven't really delved too far into the fuel system yet until I decide which kit I want to go with.
Old 12-04-2009, 04:52 PM
JPH
JPH's Avatar
You will be fine. Cometics sprayed with holymar, ARP bolts (trqd properly), a good fuel pump and a dead on tune, you shouldn't have ANY issues.
Old 12-04-2009, 05:21 PM
I figured you'd find me in here. I'm stockpiling parts already for winter. I'll bring those heads in to you ASAP.
