What Nitrous Shot??
What Nitrous Shot??
Opinions please as to what a safe Nitrous Shot would be on my car.
LPE 383 Stroker consisting of the following parts: 11.2-1 CR
J.E. Custom(forged) Pistons
Callies Crank
Manley Rods
LPE LS6 heads
LPE Stainless Intake Valves
Inconel Exhaust Valves
Nitro Dave's 90mm plate system
Racetronix Pump with plug and play harness and Kenne Bell 20amp BAP.
42# SVO Injectors
Any other info needed?
Callies Crank
Manley Rods
LPE LS6 heads
42# SVO Injectors
Guest
Posts: n/a
If they are nitrous pistons then you should be able to hit a 250+hp shot. If they are just a forged piston then 200hp could be done and maybe a 250hp shot but no more than that. It would be best to contact JE or LPE to see what those pistons are rated to. Also ring gap will play a factor in how much you can spray also.
