Will 235/55-17 fit on the stock WS6 rims?
Old 12-05-2009, 08:57 PM
thegadget's Avatar
Cool Will 235/55-17 fit on the stock WS6 rims?
Just curious, need a set of tires and found these cheap. Thanks for your help!
Old 12-05-2009, 08:59 PM
rtr2001ss's Avatar
THe tread will be almost as wide as the rim itself, and it will be over an inch taller.
Mean87SS's Avatar
Youll be streching them too far.
Old 12-05-2009, 09:04 PM
thegadget's Avatar
Talking
Thanks, you guys rock!
Old 12-05-2009, 09:56 PM
great421's Avatar
Point of Clarification:
If these are indeed 17 inch WS6 rims, then with rims at 9.5 inches wide, a 235 / 55 tire though taller (235 X 55% = 129.25 mm vs. 275 X 35% = 96.25 mm), is not wider than stock.
They'll actually be 40 mm narrower and 33 mm taller than stock.
Old 12-05-2009, 10:16 PM
rtr2001ss's Avatar
My guess, the skinniest tire you could run on a 9.5" rim would be a 265. But the 275 is more available, albeit not always super affordable.
