94 4L60e work with LQ4?
Old 12-06-2009, 06:39 AM
jbal's Avatar
Default 94 4L60e work with LQ4?
I didnt want to hijack the previous trans thread.
I am doing a low buck swap, like lots of guys, into a 688 c-10.
I have an L33 and an LQ4. I think I going with the LQ4 for the truck. I also have a rebuilt 1994 4L60e (non pwm) from a 94 roadmaster wagon.
Has anyone run a non pwm trans behind an ls motor? I can use either a blue/red pcm or a blue/green. Will I just have a more abrupt lockup? What if anything has to change in the calibration.
Old 12-06-2009, 10:20 AM
holley505's Avatar
If your road master was a LT1 chevy engine it should boltup... need different flexplate and Spacer/Adapter (I Believe because thats whats needed for TH350/TH400 applications).... top bell housing bolt is missing on LS series motors. Will have no effect on your motor and tranny.
Old 12-06-2009, 10:21 AM
holley505's Avatar
BTW the Manual LT1 Trannies will NOT bolt up... housing are different.
Old 12-06-2009, 10:59 AM
gofastwclass's Avatar
Check the transmission section to be sure but the way I understand is the non PWM transmissions are different and either require wiring or PCM updates to work properly. Best bet would be newer PWM transmission, external control or a non lockup model.
Hope this helps.
Quick Reply: 94 4L60e work with LQ4?
