quickfuel blowthrough?
Old 12-06-2009, 02:57 PM
stingr's Avatar
Default quickfuel blowthrough?
an experience with them? Good, bad tuneability.....I wanna hear what you guys think about these carbs.
Old 12-07-2009, 07:36 AM
forcd ind's Avatar
most over the counter BT carbs are just that, prob have ann. boosters, higher flow n/s's, maybe a little work on the throttle shafts, etc-to really make hi power, you need one from CSU or someone that deals in BT built to your engine specs-i have built my own, used the BG version, which needs a lot of work to not be lean-you have to mess with the PVCR's, hi sp a/b's etc
can you make them work-sure, but you need to kind of what to do to dial then in
Old 12-07-2009, 12:56 PM
Gingervitis Addict
slow67's Avatar
X2 I would use a CSU or C&S blowthru carb (they are the only 2 companies I know use boost referenced power vavles).
Old 12-07-2009, 02:52 PM
BoostnTBSS's Avatar
I have a PC carb and i i spent about 40 hours perfecting it... now i can just build my own lol but those 2 above are good picks but search on the turbo forums for a brent BRPV carb and he makes a great set up...
Old 12-07-2009, 10:48 PM
87olds442's Avatar
my friend has a quick fuel carb modified by brent davis it uses boost reference power valves and he uses a msd rpm switch box hooked up to a air pump and to be honest when i go blow through there is no doubt in my mind i will be getting one from him
Old 12-08-2009, 09:31 AM
Gingervitis Addict
slow67's Avatar
Brent's BPRV is a good one too, but he technically isn't a business
I like the idea of a CSU or C&S carb with BPRVs since they don't rely on an external pump or switch.
Old 12-08-2009, 03:54 PM
87olds442's Avatar
very good point. on both statements lol
Old 12-08-2009, 10:10 PM
cracker's Avatar
Brent Davis - Great job, Great Product, Starts with a Quickfuel.
No other choice in my book.
-W
Quick Reply: quickfuel blowthrough?
