Best drag radial with stock rim??
Old 12-06-2009, 07:08 PM
Atomic02's Avatar
Default Best drag radial with stock rim??
What is the best drag radial to get using a stock 17x9 speedline rim? All opinions and fact/pics needed... thanx
Old 12-06-2009, 09:42 PM
69TA's Avatar
for street I like to run Nitto DR's
track Mickey or Hoosier
275 40 17 sizes is what you needing
Old 12-06-2009, 09:45 PM
silverz28camaro's Avatar
Yeah if you want the extra miles out of your tires get the nitto 555r they should have them in your size, they do work good, but if you want a better time and if you are a 6 speed with a 12bolt or 9inch get the mickey thompson et street radials.
Never mind, just saw your sig, you do have a 6 speed, and if its the stock 10 bolt any drag radial can destroy that rear end so keep that in mind.
Old 12-06-2009, 10:12 PM
Atomic02's Avatar
So I've heard alot about the 315 555r's being a little narrower and fitting the stock 17X9's no problem...what do you guys think??? thanx
Old 12-06-2009, 10:14 PM
01FbTaWs6's Avatar
you want traction?? Get the hoosiers or mickey thompsons. /end thread
Old 12-06-2009, 10:42 PM
99FBODY's Avatar
I would say go with mickey thompson or bfgoodrich, I have had both and they stick nicely at the track. I have nittos on my ws6 now just cuz I bought them with the nittos. I am due for a new set of rear tires and will prolly be going with bfgoodrich just cuz they last a little longer on the street. As for the 315 nitto, yes they will fit but no dont do it.
Old 12-06-2009, 11:31 PM
hitmanws6's Avatar
dont do it. the tread will curl up so you will have the same contact patch as you would with the 275s. i run the 555R 275s on my ZR1s. they look fine and hook pretty good. i definitely recommend them
Old 12-06-2009, 11:35 PM
My buddy always runs the 315 555r's on his formula with 17x9's, he swears they hook better, he did cut a 1.64 with them.
They do squeeze in a tad but they do fit. he has als tried the 275's but now he just runs the 315's
From the back side they look pretty good. I'll try to find a pic to show you the way the bow in a little
Old 12-06-2009, 11:38 PM
315 nitto on a cobra 17x9 rim
Old 12-06-2009, 11:40 PM
You can see how it is a tad fat for the rim, but my buddy has had no issue in the 2 sets he has been through, also I run a 255 on my 8 inch stock rim and it looks the same as above with the sidewall wanting to bow in slightly, no issues with mine as well.
I think these 315's look good.
Old 12-06-2009, 11:42 PM
+10 but I have a feeling hes on the 10 bolt? And the nitto is a better(longer lasting) street tire with a touch of traction.
Old 12-07-2009, 07:13 PM
Atomic02's Avatar
Yeah I got a stock 10 bolt m6 and I realize I want nittos I just wish I could see them on a f body 17X9 rim, and maybe talk to someone who has them now or has ran them...
Old 12-07-2009, 07:23 PM
hitmanws6's Avatar
i have the 275s on my 17x9 SS wheels. they look just fine, they aren't stretched at all. they are great in the rain and hook very well. my friend on here (ZexGx) pulled a 1.8 60 foot with them in his stock LS1. his were at the wear bars. here are some pics of them.
Old 12-07-2009, 07:43 PM
NSSANE02's Avatar
The best tire in that size is an ET Street Radial. There is no comparison traction-wise between the 555R and MT's or Hoosiers. Only thing the Nittos have going for them is treadwear and they're better in the rain until they wear out, but that's exactly why they don't give anywhere near the traction of the others.
Old 12-07-2009, 10:13 PM
01FbTaWs6's Avatar
honestly, Ive got BFG's on my car now, and I dont think ide ever buy them again for anything more then a bolt on car. They held decent at the track, 1.7 60 ft times, but they SUCK on the street. Next tire will be either 28 tall Mickeys or 28 tall hoosiers.......
Quick Reply: Best drag radial with stock rim??
