ASP underdrive pulley or SLP underdrive pulley?
Old 12-06-2009, 10:04 PM
Abdullah's Avatar
Default ASP underdrive pulley or SLP underdrive pulley?
i want to buy an underdrive 25% pulley and i decided on the ASP one which is lighter the ASP or the SLP?
also can any one give me the belt brand and part # for the ASP pulley and for the SLP pulley?
thanks for help.
Old 12-06-2009, 10:37 PM
JeaneZ28's Avatar
These are Goodyear numbers TSP has listed with the 25% UD Pulleys.
Acc.
19-760K6
A/C
19-K040378
The SLP pulley is supposed to be the same as the Powerbond and you will have better luck finding PB cheaper.
Here is thread where Scoggin Dickey said they will create a package deal for $200 (includes powerbond pulley and belts).
https://ls1tech.com/forums/generatio...e-pulleys.html
Old 12-07-2009, 04:00 AM
Abdullah's Avatar
thanks for the info.
Old 12-07-2009, 02:38 PM
youguessit's Avatar
never heard of the slp/powerbond pulley failing.... cant say the same of the asp.
Old 12-08-2009, 06:22 AM
toadzq8's Avatar
I would recommend installing a manual belt adjuster like the Ketec if you are going to run a underdrive pully.
Old 12-08-2009, 07:06 AM
Mikes96z's Avatar
The high walls of the SLP/Powerbond is said to keep the belt better aligned.
Old 12-08-2009, 07:18 AM
teke184's Avatar
i've had the ASP unit on my car for 6yrs....only dropped a belt once...and even that was years ago
Old 12-08-2009, 07:36 AM
SMOKNSS's Avatar
I have a ASP on mine and it is a nice piece. You can definately see the upper tensioner flex while the car is idling.
Old 12-08-2009, 08:19 AM
slt200mph's Avatar
I have been running a underdrive pully (SLP) for well over 150,000 miles ... yes I said 150,000 miles with the stock belt tentioner with no problems at all .... the belt tentioner has 197,000 miles on it and its still going strong...if this LS1 would ever wear out I'd build a bigger motor.
Old 12-08-2009, 10:00 PM
Abdullah's Avatar
which 25% pulley is lighter? the ASP or the SLP? which one will give better et and mph at the track?
thanks.
Old 12-09-2009, 05:46 AM
teke184's Avatar
considering even the best underdrive only yields <10hp....and probably ~.1sec .....any of them that are the same % should be basically identical.
its not like the difference between shorties and LTs....
Old 12-10-2009, 06:16 PM
Redneck Z's Avatar
The gains should be identical, but it's the reliability(no belt throwing) that matters. I have heard alot of threads where the ASP pulley's have thrown belts. You don't hear that about the SLP/Powerbond pulley, because it has a higher retaining wall so belt throwing isn't a problem. I've had a powerbond on my car for 3-4 years and have never had a problem. I vote SLP/Powerbond.
Old 12-10-2009, 06:45 PM
ShortChevy's Avatar
I am sorry but I do not ever see any threads about ASP's throwing belts. All is EVER hear about is how the Powerbond/SLP has higher retaining walls so it doesn't throw belts. I have a ASP and have never lost a belt, granted I'm only spinning 6k but I doubt I'll have a problem when that is raised to 6700RPM. All with the stock tensioner.
Old 12-10-2009, 07:34 PM
FirstLSx's Avatar
I've had no issues with my SLP pulley. Would highly recommend it.
Old 12-10-2009, 07:42 PM
JeaneZ28's Avatar
I seen a bunch of threads where there has been problems with asp pulley throwing belts. If you haven't had any problems good but I don’t see any reason to buy ASP when you can get the SLP/Powerbond for cheaper.
Old 12-11-2009, 12:30 PM
Abdullah's Avatar
thanks for inputs.
OK, at the track which pulley will lay best et and mph? the 25% UD ASP pulley or the 25% UD SLP pulley?
i'm saying that with correspondance to weight of each pulley since they say the whole SLP pulley are made of steel while i think if i'm not mistaking the ASP are made of aluminum and steel, what are your inputs on that?
Old 12-11-2009, 12:56 PM
99blancoSS's Avatar
Your better of with an ATI Superdamper -lightwerweight and better quality. You can order them with the correct rubber for your application as well. Hi rpm hi hp use is different than normal street setup.
Old 12-11-2009, 01:53 PM
01ssreda4's Avatar
ATI I believe is the hands down best UD pulley for LS motors. And they are priced respectively. Im running a Powerbond with no issues. Asp is lighter then SLP/Powerbond. Difference wont matter between the three at the track as far as weight goes.
Old 12-11-2009, 06:49 PM
Redneck Z's Avatar
Yeah, there were quite a few threads regarding the ASP's throwing belts when I originally looked into them about 3-4 years ago. Thats the sole reason I went with the Powerbond pulley instead. He might get lucky and not have a problem with the ASP like you, but why take the chance when you can just buy the SLP/Powerbond pulley and not worry about it at all?
Old 12-11-2009, 09:13 PM
dgu1rt's Avatar
about how much does the ati ud pully cost and what kind of power increase does this make?
Quick Reply: ASP underdrive pulley or SLP underdrive pulley?
