K-member and front A-arms for corner carver good idea?
Old 12-06-2009, 10:32 PM
chevystyle's Avatar
Default K-member and front A-arms for corner carver good idea?
Are these a must upgrade or won't make a difference. I see a lot of handling packages on line and none have K-members or front A-arms for upgrade. Just wandering if it'll make a difference or not. Thanks.
Old 12-07-2009, 12:53 AM
mediocrels1's Avatar
not worth the money unless your stockers are damaged in some way or you're about to race down pikes peak lol
Old 12-07-2009, 01:27 AM
xXxSilveradoxXx's Avatar
I suppose it all depends on how hardcore you wanna corner carve. I've got Koni 4/4s and Strano springs and sways and I can hit ludicrous speed in the twists and turns. An aftermarket K-Member and A-Arms would make a difference but are in no way "required".
Old 12-07-2009, 04:10 AM
99Bluz28's Avatar
Go with stiffer GW bushings on the factory upper arms and UMI with rod-ends for the lower A-arms, it works really good for me!
Quick Reply: K-member and front A-arms for corner carver good idea?
