4l60 manual valve swap, anything I need to know
Ok been fighting the electrics in my tranny for to long, it's come down to swaping to a 700r4 or valve body, new tranny so I prefer to go to a full man 4l, few questions first, what kit is recommended?,will I have od, any tq converter issues? Will I need a new shifter? And any other imput would be greatly appreciated,
thanks guys and gals
i did it. I used the transgo kit. You will have overdrive. No converter issues. You can still have it locked up by the converter or do like I did and set it too a switch. A shifter is nice but not needed. The thing that bugs me is you have to push the button to go back once you put it on drive.
Yes sir. I did use the hd-3 kit. I just ran the lockup wire to a switch.
I think i called performabuilt and they told me which wire it was. If I remember correctly all I had to do was ground the wire and the would Lock up.
