TH400 Driveshaft
Borrow a bare case and install it with the mount on the crossmember. Measure from the rear seal to the flat of the yoke, (where half of the u-joint cap is exposed). The trans and diff have to be installed at ride height with the weight of the driver in the seat for the most accurate measurement. You don't want vibrations or a shaft that bottoms out when you drive over a bump.
I bought a th400 and driveshaft from a buddy that also ran a moser 12 bolt. The driveshaft was 15/16" too long on my car and had to be cut. It was perfect on his f-body. I think every car is different and should be measured for proper fitment.
