Question? 12 bolt on 83 Camaro Z28, Need help!!!
Old 12-07-2009, 04:20 PM
MAXXLIMIT's Avatar
Exclamation Question? 12 bolt on 83 Camaro Z28, Need help!!!
I am looking into swapping a 12 bolt into my 83 camaro. The question I have is which 12 bolt from what vehicle will mount right up and be ok. Lug patterns, width, and bolting right up.
Which vehicles do I need to start looking for and any mods I will need to do???
Also can I use stock torque arm setup?
Any help would be great.
Old 12-08-2009, 01:11 PM
supermouse4's Avatar
Just go with a 12-bolt from Moser Engineering or Strange Engineering if you have the money. These rear ends are bolt on and will work fine with your application. You should call up Moser or Strange and talk with them and have them answer all your questions, they should help you out just fine.
I mean, it would be time consuming to have to find a regular 12-bolt and finding out which vehicles would be compatible and interchangeable with the 83 camaro outside of any additional repair that you might do.
Old 12-08-2009, 01:45 PM
209ryder's Avatar
hit up jaws gears too he is a cool guy and has decent prices too
Old 12-08-2009, 02:53 PM
Marc 85Z28's Avatar
None. You have to go with an aftermarket housing unless you want to completely redesign the rear suspension.
Old 12-09-2009, 08:40 PM
I agree with the previous two posters. The old GM 12-bolts are not compatible for your 83 camaro unless you want to redesign your rear suspension.
Old 12-09-2009, 09:18 PM
MAXXLIMIT's Avatar
hey guys thanks for all the input. After doing some thinking a aftermarket 12bolt or 9 inch will be a better bet
Old 12-10-2009, 04:24 AM
EPP
EPP's Avatar
Check out my prices on a Moser 12 bolt. http://www.exoticperformanceplus.com....html?item=146 Bob
Old 12-10-2009, 04:37 AM
The Manalishi's Avatar
Didn't see an option for c clip eliminators is that available on those rears or is it standard an I missed it?
Old 12-10-2009, 07:08 AM
Internet Mechanic
BlackScreaminMachine's Avatar
My moser 12 bolt, the C clipers Elim. is standard, they use a bearing pressed on to keep it in the rear.
Old 12-10-2009, 11:11 AM
Jawsgear's Avatar
Most aftermarket differentials are using a 9" ford housing end, so it is converted to a bolt in style axle instead of the stock c-clip axle.
Jeff
