which wire on clutch switch for 12v 2step activation?
got my msd 8733 two step today and need to know which wire on the 4 wire connector for the clutch switch to use for the 12v activation signal. theres a brown/white, pink, gray, and black/white. i played with a test light today and the only thing i could figure out was that pink was always 12v with the clutch in or out, i couldnt get a trigger off of any of the other ones.
i know if all else fails i can jump the two wire switch and use the starter safety switch as a switched ground but i would prefer not to disable it.
thanks
thanks
Check out page 8 of this document. It may help you....worth a shot.
http://www.lingenfelter.com/sites/li...ler%20v1.3.pdf
