Painting calipers
Old 12-08-2009, 02:33 PM
KEVS98LS1's Avatar
Default Painting calipers
What product is everybody using to paint their calipers these days.I need to freshen up mine.Also what is the exact process in cleaning them to paint.
Old 12-08-2009, 02:36 PM
JeaneZ28's Avatar
I used dupli-color caliper paint and it worked fine. You can get it at your local auto parts store.
Old 12-08-2009, 02:44 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
DUPLI-COLOR or VHT.
Old 12-08-2009, 08:06 PM
transwiz's Avatar
I also used dupli-color for my calipers.I cleaned them with a wire wheel on my drill
and then cleaned them with M.E.K. before painting them.
Old 12-08-2009, 08:13 PM
KEVS98LS1's Avatar
Thanks.You guys
got any pictures.
Old 12-08-2009, 09:00 PM
Squirts11's Avatar
Make sure to clean them well, sand them down to a smooth surface, clean with acetone or similar product to degrease, then apply multiple coats.
I used VHT caliper paint. Has worked well so far with no chipping.
Old 12-08-2009, 09:25 PM
4150's Avatar
I used Duplicolor caliper spray on my daily driver, turned out nice other than the fact it took about a day before the paint wasnt tacky. I blew everything apart to wire wheel and clean. Everything was painted separately and the calipers were carefully masked off.
I recently took everything apart to do another brake job, red on a DD is a complete bitch to keep clean so I stripped off all the red and repainted everything with semi-gloss black Duplicolor engine enamel. Red looked good for about the first 20K miles or so but cleaning it was a pain since the only way to really get everything clean again was by taking the wheels off. I didnt have any problems with chipping but the color changed slightly, kinda changed from bright red to a darker red over a 2 year period.
Old 12-08-2009, 10:14 PM
00RedMaro's Avatar
I want to do a gloss black on mine too, but I'm also thinking about those caliper covers that MGP or whatever have for sale. I don't have the time to take the brakes off my DD.
Old 12-09-2009, 04:04 PM
Trunion King
bene's Avatar
I used brake cleaner/chrome wheel cleaner to clean the brake dust off. Then I used the dremel to smooth out the casting marks. Cleaned it again from the debris, prep it for painting, then used Duplicolor paint/cleared right after.
Old 12-09-2009, 07:44 PM
KEVS98LS1's Avatar
I have decided since my ride is black I am going to go with gloss black.Black really should hide the dirt.
Old 12-10-2009, 04:30 AM
Trunion King
bene's Avatar
I went w/ gloss black.
Old 12-10-2009, 04:36 AM
hitmanws6's Avatar
i cleaned mine with a wire brush and soapy water, then sprayed with OSH red spray paint. still looks fine after 2 1/2 years
