WTB: LS1 Radiator Hoses
str8rpn,
Hey, we are OE Parts Headquarters and a sponsor for LS1TECH. We have both hoses in stock and ready to be shipped. The links below should take you to our site and display the parts you are needing.
The upper hose is a 24294L $31.37
The lower hose is a 24353L $19.59
Remember that orders over $75.00 will receive free UPS ground shipping and all other order are 6.99 for standard UPS ground. If you order please be sure to include the code LS1TECH to apply discounts on your order.
Thanks for the opportunity to quote on your parts needs.
Curveball TECH
I actually just replaced the lower hose yesterday - Have fun with the dumbass clamp on the lower radiator side.
I was going to replace the upper as well but didn't realize there are 2 smaller hoses running into the pvc(ps cooling?), and the autozone hose I bought had no connections into the bottom(I guess it is a cut to fit around the pvc section, but I want to replace everything). OEHQ I see your upper hose has the needed connection for one of the hoses underneath, but where would the second one plug into?
