Spare Tire for '08 GXP ??
I put a set of Blizzaks on '04 Comp-G wheels on the wife's '08 GXP. I found a jack with the foam insert, etc now I need a spare tire. Will I need a 16" or 17" compact spare? I was looking around eBay but wasn't sure what I needed as IF the GXP would have come with a spare. Would the 17" compact spare fit in the spare tire well in the trunk? One of you guys has probably figured all this out already. Thanks
No 16" rim will fit the GXP, best bet would be to find another Comp rim, because I'm unsure as to whether a compact 17" will fit either, the only downfall of larger rotors.
I recently acquired a rear GXP rim that will be my spare. I plan on it just chillin' in my trunk, doubt it'll fit in the hole that they so lovingly teased us with.
The 16" that comes in V6 W-bodies may fit the rear....maybe. I got a flat on my right rear on the GXP a couple weeks back. Once I got the car home I threw it on just to see if it would clear the calipers and theres about a hair width if I remember between the caliper and the valve stem. I wasn't going to drive it to the shop like that but I goofed and totally forgot and drove it...it made it but it was only a short distance. So there is NO way of course it would clear the front calipers.
Solution for GXP spare http://www.clubgp.com/newforum/tm.asp?m=4007587
Look at how tight that is over the brakes...
