T-56 with 2010 camaro LS3...will it work?
I was wondering what the spline count is on the stock t56, and whether it will mount up with a ls3(L92 I believe). Any input would be great! Ill be tossing this into a 1993 rx7, found a great deal on a 2010 camaro ls3!
Yes you can use T56 behind a LS3. The input shaft splines doesn't engage the trans, it's the very tip that rides on the pilot bearing.
No you can't use the new Camaro clutch. The slave is different. Just use any LS1 T56 clutch and flywheel.
