LS4 Performance - HID ballast mounting?
xxmerc1914xx
12-09-2009, 03:59 PM
i was looking at buying a set of HIDs for the impala and i was wondering where everyone here mounted their ballasts? and if anyone has any feedback on http://www.hidextra.com/HID+Conversion+Kits/Automobile+HID+Kits/H11+HID+Kit/H11-6000K.htm. thanks
CenTexSS
12-09-2009, 05:51 PM
I mounted my ballasts for my headlamps on the front support beam that runs from headlamp to headlamp.
My fogs are mounted on the inside of the bumper cover.
No pics though.
20SS07
12-09-2009, 06:36 PM
Mine really weren't even mounted. At first I had them mounted to factory grounds but it was screwing up the ground, so I just left the drivers side right behind the headlight and the passenger side kind of in the area behind the fender behind the headight, kinda hard to explain. With the headlights in place they didn't move at all. CenTexSS probably has a little better method haha.
xxmerc1914xx
12-09-2009, 06:44 PM
thanks alot its pretty confusing looking at at these and having no clue where to start
20SS07
12-09-2009, 07:06 PM
It's not so bad once you have it in front of you and lay it out and see what you're doing. Pretty straight forward install. If that kit doesn't come with a relay harness, I'd personally recommend getting one. Some will come in and argue til their blue in the face that you don't need one, but for 10-15 bucks it's cheap insurance to not fry your stock wiring.
xxmerc1914xx
12-09-2009, 07:14 PM
yeah ive seen the arguments, id rather spend 15 bucks and be safe than have something short out
1CL3ANSUP3RSPORT
12-09-2009, 08:15 PM
that how i did mine right behind the driver side and passenger side headlight for both the low beam and fog light.ill post pics tomarrow when it sunny outside,if it doesnt rain...
Jay z28
12-09-2009, 09:41 PM
I used self tapping screws and screwed them into the support beam like stated above. I also tried to mount in on the grounds, but my trip computer kept saying that my trunk was open whenever I turned on the left blinker. All it took was once driving home from work and that annoyed me enough to change the set-up.
xxmerc1914xx
12-09-2009, 10:05 PM
thanks alot that will help a ton
hahahaha i gotta say thats alittle hilarious
BuffaloSS
12-09-2009, 10:15 PM
Here's a brief writeup I did for my first HID kit install. Most of it still applies.
http://www.naioa.com/v2/modules.php?name=Forums&file=viewtopic&t=19821
20SS07
12-09-2009, 10:38 PM
I'm glad I finally found someone who had the ground mounting issue. Mine was even worse. Every time I turned on my fog lights or high beams, it would say my hood was open, not to mention the lights wouldn't actually turn on properly. One high beam would come on at reduced power and one fog light would be dim. It was weird. Took me awhile to track down that the HID's were causing the problem.
