Drag Racing Tech
can you run taller than a 28" slick on a 4th gen?
Old 12-10-2009, 02:06 AM
c5formula's Avatar
Default can you run taller than a 28" slick on a 4th gen?
well thinking about my rear gear issues and how im going to run out of gear on the spray with some 28"s. well i much rather just switch out the tires than the gears.
so can i run say a 29" or 30" tall tire on the rear of my 97 formula firebird or am i going to have to modify something??
Old 12-10-2009, 02:36 AM
01SOMZ28's Avatar
i think anything bigger than a 28" you're going to have to cut the bumper for sure, not sure what else.
Old 12-10-2009, 07:49 AM
LS1TECH Sponsor
Steve Burger's Avatar
I have a 29.5 on mine and had to do a bit of work to the cover as well as the tubs.
Old 12-10-2009, 01:12 PM
c5formula's Avatar
steve, what all did you have to do to your car to make those fit? any way you could post up some pics?
Old 12-10-2009, 02:00 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Steve is about as good of an authority as your going to get. I would PM him. Sounds like you want to fit the biggest tire but not have to cut up the car.
Old 12-10-2009, 10:25 PM
Minshall's Avatar
Im running 29.5s. I had to cut the rear bumper a bit and take a flapper wheel on my grinder to the lip of the fender. I didnt have to take much off the fender. maybe an 1/8th of an inch. As long as you have a panhard bar itll make things much easier.
Old 12-11-2009, 12:55 PM
c5formula's Avatar
yeah i dont want to have to cut up the car as this is my baby lol and my DD. i just need to be able to run a taller tire when i go to the track an thats it. i really dont wanna hack my car up ya know.
Old 12-12-2009, 10:48 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,088 Likes on 716 Posts
When you go from a 28 to a 29, 29.5 or 30 inch tire you have to start cutting the front and rear metal/plastic. You might also have to cut back the area near the front LCA mounting point.
I've often thought one way to minimize the surgery would be to run a longer driveshaft and push the rearend back a bit. Then you could just cut the rear bumper back.
Hoosier makes a 29x10.0 slick I think, that might the least intrusive tire to move up to.
Old 12-12-2009, 11:17 AM
Race your car!
JL ws-6's Avatar
That tire will fit, but even it needs extra clearance. 28x10 is about as big as you can go, unless you go with a radial that doesn't grow at all, in that case you can get away with a 295, but the car will need a minitub. If you pull the tires in an inch, you probably can get away with a little more.
Old 12-12-2009, 01:45 PM
SlickVert's Avatar
Bogarts and 28" will fit.
Bob
Old 12-12-2009, 03:28 PM
Race your car!
JL ws-6's Avatar
The burkhart front end I bought has the arms narrowed an inch to pull the tires in a little, I'm 100% sure it will clear.
Not sure if I'll need the clearnace/height back, I only had an inch of drop built in not 2.. if I went with the 2 inch drop, a 28 inch tire would absolutely be needed.
Quick Reply: can you run taller than a 28" slick on a 4th gen?
