WTB: 9" or 12 Bolt..
Looking for a deal on 12 bolt or 9" w/ abs & posi or locker.
would prefer 3.2X to 3.90ish gear range.
If you have LCA,PHB and/or toque arm to go with it, let me know.
Can spend about $2000.
Thanks
Thanks
I got a moser 12 bolt with no whine, it got around 9k on it and its ready to go in brakes and drive shaft go with it its a 3ch ive been told all the wiring and sensors are there 1500 plus pay pal and shipping
moser 9". detroit locker, 31 spline moser axles, arp longer wheel studs (can't remember exact length off the top of my head), 4.30 gears
Can also include a umi tunnel mounted torque arm for longtubes, with a built-in driveshaft loop.
Was looking for 1900 for the rear, without torque arm.
i have a moser 9" 31 spline axles true trac aluminum center section with 4.10's but have a set of 3.50 gear that go with it. it does not have abs. it has lca relocation brackets welded on. its stock width. i am in the austin area. pm if this is something you would be interested in.
Yes,how much? Do you have any pics?
