98 TA ABS/ 3 or 4 channel?
Old 12-10-2009, 09:30 AM
conde'strans's Avatar
Default 98 TA ABS/ 3 or 4 channel?
I have a 98 TA with ABS but how can I know if it's a 3 or 4 channel?? Are all 98 A4's the same regarding this? Help me out guys I need to know this cuz I'm looking into buying a 12 bolt from someone on here.
Old 12-14-2009, 05:53 PM
1SweetSS's Avatar
ABS only? or abs and traction control...............ABS only is 3 channel.......abs & traction control is 4 channel
Old 12-14-2009, 06:32 PM
01ssreda4's Avatar
correct......
Old 12-15-2009, 04:58 AM
EPP
EPP's Avatar
ABS only plugs into the top of the center section of the housing.
ABS/TCS does not have a connection in the center section, it plugs in out by the brakes. Bob
Old 12-15-2009, 03:38 PM
I've been offered a pretty good deal on a 9" that doesn't have ABS could I just buy an ABS delete box(so I've heard exists) and make it work? How much of an impact would that make driving my car without ABS? Educate me please!
Old 12-15-2009, 03:45 PM
jetlag's Avatar
Have you ever felt your brakes pulse? If no, then you've never used ABS.
Old 12-15-2009, 03:54 PM
So you're saying it be fine then, as if I had it? I was just wondering since I'm trying to make up my mind on it.
Old 12-15-2009, 04:18 PM
EPP
EPP's Avatar
Without ABS hooked up on the rear you will not have ABS on the front brakes either. ABS stands for anti-lock braking system, without it you will be back to old school threshold braking, which I prefer. With old school brakes if you stand on the pedal, you're going to lock up the brakes, which can result in a magnificent looking skid mark, or you could end up in a ditch... With old school brakes you learn where the point of lock up is, which is how hard you want to apply the brakes in a panic situation.
With your ABS disconnected you will have a light staring at you on the dash, there is no way to tune it out, either live with it, pull the bulb out or put some black tape over it. You can remove the ABS assembly, which will remove 14 lbs of wight from the car. It will clean it up so it looks better, but you'll still have that stupid light to contend with. Bob
Last edited by Exotic Performance Plus; 12-16-2009 at 05:16 AM. Reason: Dumb ass attack
Old 12-15-2009, 05:03 PM
jetlag's Avatar
My car brakes just fine without it, but I don't go around slamming on the brakes. If you get in a bad wreck, ABS might have been able to save your car from locking up and skidding, or maybe not.
On some older cars, ABS was an option. My friend's 1995 Mustang GT doesn't have it and he never had a problem.
Old 12-15-2009, 05:44 PM
The hell with ABS then, you've convinced me! One more thing though, for like a year now the LOW TRAC light turns on every time I brake and I wonder if eliminating the ABS would eliminate that as well?
Old 12-15-2009, 09:30 PM
ThoR294's Avatar
Without ABS hooked up on the rear you will not have ABS on the front brakes either. ABS stands for automatic braking system........
stands for ANTI-LOCK BRAKE SYSTEM <3
Old 12-15-2009, 11:38 PM
jetlag's Avatar
True, but technically doesn't it do it automatically for you?
Old 12-16-2009, 05:15 AM
EPP
EPP's Avatar
Oops, you're right. Automatic will probably be next, we won't even have to put the brakes on, they're do it for you. lol Bob
Old 12-16-2009, 05:59 AM
rpmauto's Avatar
on a 98 you can get the ABS delete kit from sjm with a line lock (awesome) and you can turn off the abs, trac light. No problem at all. Plus your brake light will still work with the e-brake and if your fluid is low. I would have to look it up, but you ground a wire in the abs connector. The sjm kit is the way to go though, you get a adjustable proportioning (spelling) valve to go inline with the rear. Without abs you loose rear brake bias, ie your rear brakes get the same pressure as the fronts and could lock up sooner than normal.
Quick Reply: 98 TA ABS/ 3 or 4 channel?
