What kind of timing are you guys running on your F/I setups???
Old 12-10-2009, 02:36 PM
WickedC5's Avatar
Default What kind of timing are you guys running on your F/I setups???
I'm currently at 14deg of timing on my forged 347/F1C setup (18# of boost). Just looking to see where the rest of you guys are at timing wise on your tune.
Thanks,
Old 12-10-2009, 02:47 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I am at 20° on pump gas only right now (I have alkycontrol kit, but not using it right now because it is already running pig rich on 91 octane alone). Forged 9.2:1 370/ F1 at about 12-13psi.. ~700rwhp and still working out the bugs.
Old 12-10-2009, 02:51 PM
Fireball's Avatar
over 20* and over 30psi
Old 12-10-2009, 03:15 PM
TWS
TWS's Avatar
18* at 9 PSI on my Vortech car.
17* at 10 PSI on my Procharged car.
Those are on 93 pump gas tunes.
I'm at "baby boost" levels compared to many other members.
Old 12-10-2009, 05:40 PM
SPRAYED 01's Avatar
15 @ 15.5psi, 8.8:1 COMP on pump gas. Just make sure you have your tune setup to pull a bunch of timing if your iats go past about 145ish. I blew a forged motor that way. 180 iats on pump gas is not your pistons friend.
Old 12-10-2009, 08:38 PM
conan's Avatar
17 deg, 10#'s of boost, 91 octane, 9.4:1 compression. I'm droping from a 3.7" pully to a 3.4" (14-15 #'s) and adding meth this winter, I'll probly leave the timing at 17-18 deg and have the safety of the meth.
Old 12-10-2009, 08:43 PM
ninetres's Avatar
19* 110 octane and big meth
Old 12-10-2009, 08:53 PM
HUNTER02SS's Avatar
18.5deg on 13-15lbs, and 19.5deg on 23lbs so far on C16 fuel.
Old 12-11-2009, 09:20 AM
WickedC5's Avatar
Sounds like I'm leaving some power on the table by keeping my timing so low. Keep the info coming guys!
Thanks,
Old 12-11-2009, 09:35 AM
forcd ind's Avatar
i think i was around 12 lbs boost, IAT's a little over 100 degs, 93 octane with a splash of 110, 22 degs put the timing mark right at the curve on the plug,
i think the AFR's were around high 11's, low 12's, but i run a carb, so prob a little better cooling in the engine-i start at 30 degs, ramp up a little higher in cruise mod, then drop timing as the boost goes up-i think my comp is around
9.2
Old 12-11-2009, 10:36 AM
VTC_WS6's Avatar
When you guys toss these timing figures out there, are you talking about peak timing? Or more importantly, peak VE/TQ timing which is what I'd be more interested in knowing..
Old 12-11-2009, 10:41 AM
HUNTER02SS's Avatar
Timing at peak I would guess.
Old 12-11-2009, 10:52 AM
Louis's Avatar
Timing from another setup across the country doesnt mean much. Take it with a grain of salt for sure CRs, Boost, Fuel type, etc all play a big role.
Old 12-15-2009, 11:56 AM
TWS
TWS's Avatar
Update to my input.
Just turned the timing down to 15.5* on the Procharged car during a dyno session this morning. 10 psi on a stock longblock. Making absolutely sure we stay out of detonation. 542 RWHP/488 RWTQ SAE. OUT OF INJECTOR from 5300 on up. 42#'s are coming out, starting to shop for some 60#'s.
Also looked at the tune on the Vortech car. We had turned it down to 16*.
Yeah, I think the OP knows that he has to carefully tune his own car and that what we run on our cars is just interesting reading rather than accurate guidance for his setup - which can be greatly different from other posters in this thread.
Old 12-15-2009, 12:32 PM
Frost's Avatar
why do you guys run one value for timing at WOT; these aren't SBC's with locked distributors?
Old 12-15-2009, 12:47 PM
HUNTER02SS's Avatar
My values I quoted are at peak RPM/Boost. The lower the rpms and boost the more timing I have.
Old 12-17-2009, 01:55 AM
GrannySShifting's Avatar
11#s 15.5 degrees on 93 seems pretty conservative then?
Old 12-17-2009, 01:48 PM
bravoboost's Avatar
12* of timing, 15lbs, 9.7:1. 91pump and 50/50 meth, 364c.i., afr's 11.0-11.7. I feel like I have alot of power left of the table via timing as well. I like "safe" though
Old 12-17-2009, 02:01 PM
Restricted User
98Z28CobraKiller's Avatar
In theory, your timing should be lowest at peak torque and ramp up towards redline. I run torque timing all the way across because I'm not trying to set any records and not class racing.
Old 12-17-2009, 02:10 PM
E-Works's Avatar
a good reference for anything over 20lbs without an air to water cooler even with race gas is 16* total timing
unless you datalog everything and you know what your engine is exactly doing and what your IAT are as stated above you don't want to push it
it also makes a huge difference in you combustion chamber design as to your cylinder temps
but at 16 * the odds of rattling it are very very low if your running good gas
pump gas 15 #s of boost and 16* total timing is pretty safe as long as your IAT's are decent
Quick Reply: What kind of timing are you guys running on your F/I setups???
