Lt1 gurus please come in!!!
Old 12-11-2009, 11:10 AM
wantsum410's Avatar
Default Lt1 gurus please come in!!!
I have a 1980 monza in the shop we have set up with a '96 camaro lt1/auto,all stock with egr/smog delete,headers & exhaust.The car starts & runs fine but will idle up around 1800rpm after it has run a couple of minutes.There are no codes,has new t/b gaskets,checked for vacuum leaks with none found.Once it idles up it never idles back down.The first 3/4 start ups it did fine & gradually led here.Thanks for any help!!
Old 12-13-2009, 08:14 PM
RyanA's Avatar
throttle is all the way closed? Double check for vacuum leaks if it is. Unless the IACV is just sticking open, I'd say you have a leak somewhere. Brake booster hose hooked up? Booster is not bad?
Old 12-13-2009, 09:34 PM
IllusionalTA's Avatar
stock untouched motor?
Old 12-20-2009, 02:06 PM
wantsum410's Avatar
Default lt1
The mtr is stock except for egr smog delete,headers.I have checked for vacuum leaks over & over there are none,I have even changed pcm with an extra I had with no change.Last scan showed #4 misfire code.I am leaning toward the iac mtr just was looking to see if anyone has had this issue.Thanks for all the help!!
