Tranny problems !
Tranny problems !
All my tranny is doing it not locking up in OD ,,, When im giving it WOT it shifts fine all through the gears, Then when I let off sometimes it locks sometimes it doesnt, if it doesnt it take like 2 min or so to lock up ..
I think its my lock up noid ? any other sugestions?
i had the same problem today....can TOO MUCH tranny fluid have anything to do with it???(have to check my fluid level again but i think i may have put too much in)
Moderator
Misfires (or what the PCM interprets as misfires) will
make the TCC unlock. Misfires can be pulled up with a
logger EFILive or ATAP), you might check this out before
getting into the hardware too deep. Something as simple
as a fouled spark plug or bad plug wire could be doing it
to you.
to you.
