Going to 4.10s
Old 12-11-2009, 07:31 PM
Bobs-00-SS's Avatar
Default Going to 4.10s
I have a 2000 camaro, 6- speed with factory 3.42s. Do I need to run an extra thick ring gear if I go to 4.10s? thanks
Old 12-11-2009, 07:39 PM
01ssreda4's Avatar
No, you will need the thinner version, the 3 series.
Old 12-11-2009, 07:56 PM
shtnfrds's Avatar
^^^ the 3-series is what youll need.
depending on miles might look into a full bearing kit while youre at it.
thunder racing sells a kit complete with eveything for 400, and then jaws gear will price match that plus free shipping from what i recall.
Old 12-13-2009, 07:43 PM
Bobs-00-SS's Avatar
Ok so I can just order a standard set of gears and be fine then right? whats the steepest gear I can run with the 3 series carrier? Also the car only has 20 k miles so bearings should be fine.
Old 12-13-2009, 07:44 PM
Bobs-00-SS's Avatar
The reason I am asking is I thought the 3 series carrier could only support up to a 3.80 gear before having to go to a thicker ring gear or spacer
Old 12-14-2009, 01:09 AM
01ssreda4's Avatar
Just order up the 3 series 4.10 and you're good. Highest I have seen is a 4.56 I believe, but who knows what all is out there. 3 series 4.10s are a direct bolt in.
Old 12-14-2009, 05:20 PM
In-Zane Moderator
ZONES89RS's Avatar
I broke a set of richmond 4.10s in my 89 with a 350 that ran 13.87 launching like a sissy with a 1.9 60. I hate richmond.
Old 12-15-2009, 01:29 AM
Ironxcross's Avatar
Wheel hop.
Old 12-16-2009, 09:54 AM
In-Zane Moderator
ZONES89RS's Avatar
Nope.
