Removing Oil Filler fr Valve Cover
Old 12-11-2009, 09:06 PM
BBPanel's Avatar
Default Removing Oil Filler fr Valve Cover
So what's the secret (fbody 2001) - I know its like a cam lock and should twist off but I've tried twisting, pushing and twisting, and pulling till I'm blue. Gotta be easier than what I'm doing! -Bob
Old 12-12-2009, 08:30 AM
gofastwclass's Avatar
Wrap some det cord around it....
Are you talking about the composite extension? If it's like my truck engines it is a b!@(# to turn. There IS a cam lock on it and once you get past that it will nearly fall off. It unscrews the same direction as the oil cap.
Hope this helps.
Old 12-12-2009, 08:44 AM
Pop N Wood's Avatar
I pulled the valve cover and got to easily from the inside. LS motors have reusable valve cover gaskets so it is not a big deal to do.
Old 12-12-2009, 08:59 AM
BBPanel's Avatar
Originally Posted by gofastwclass
... If it's like my truck engines it is a b!@(# to turn. There IS a cam lock on it and once you get past that it will nearly fall off. It unscrews the same direction as the oil cap.....
So did you have to push or pull before twisting or just twist?
Old 12-12-2009, 09:00 AM
BBPanel's Avatar
I thought about taking it off but can you really see anything that helps from the backside? The locking portion is on the side isn't it?
Old 12-12-2009, 10:13 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
I pulled and mine came off........though it was still a pain!
Old 12-12-2009, 03:13 PM
Pop N Wood's Avatar
I don't remember exacty. I do remember it was obvious how to get off once I got to the back side.
Old 12-12-2009, 04:52 PM
ls1nova71's Avatar
I've had them as easy to remove as the oil fill cap, and next to impossible to remove. I think if the o ring drys up it kinda seizes on. I looked at the back of a valve cover, but didnt see anything to push on to make it easier to remove. I'd just try a big pair of channel lock plyers if it were me.
Old 12-12-2009, 06:25 PM
CarolinaLS1's Avatar
what's the best source for a short one (F Body style)?
Old 12-12-2009, 06:32 PM
eseibel67's Avatar
I tried reefing on it and gave up.
I'm sure it was going to break because it's plastic.
Old 12-12-2009, 08:07 PM
BBPanel's Avatar
Well an 8" pipe wrench works!! There is a little tab that needs to be depressed if you knew it was there (I didn't and about half of it broke off - but I think its still usable) - I couldn't see it from the back side.
Quick Reply: Removing Oil Filler fr Valve Cover
