yellow goop in throttle body vaccum port and oil cap
Since i put a catch can on my car due to a broke pcv line i get a yellow goo in my throtle body and just noticed it under my oil cap the other day.the system is hooked up right.i used a diagram that i found on here.there is never any water in my oil when i change it.i suppose this is stuff making it past the catch can.any way to stop this?
Yellow under the oil cap means moisture in the oil. Make a lot of short trips? If you make a lot of short runs and the oil doesn't get hot enough to burn the excess water, thats what happens.
As far as the TB.......WTF? No clue.
