non adjustable torque arm (-2)on a lowered car
Old 12-12-2009, 08:18 AM
Thule's Avatar
Default non adjustable torque arm (-2)on a lowered car
i am thinking about UMI non adjustable, my car is lowered 1.2"
do i need the adjustble one, or is the non adjustable fine?
Old 12-12-2009, 11:09 AM
Grifter's Avatar
You need an adjustable PHB. The non-adjustable ones are made for stock ride height.
Old 12-12-2009, 12:56 PM
Thule's Avatar
PHB= panhard bar? if so, i will be running watts link,
Old 12-12-2009, 03:13 PM
Grifter's Avatar
Wow, yeah sorry I totally misread your post.
I don't believe you would need an adjustable tq arm when being lowered but I'm not sure.
Old 12-12-2009, 08:05 PM
therealcreeper's Avatar
why do you feel that you need a torque arm? are you just afraid of breaking yours, or are you having wheel hop/traction issues?
i have a non adjustable edelbrock torque arm(got it extremely cheap) which i believe is the same setting as stock, and it helped eliminate the rest of the wheel hop on my lowered car. adjustable isn't absolutely required, but it's probably a tad better.
Old 12-12-2009, 08:20 PM
02Z28LS1's Avatar
honestly, i would get the adjustable one. UMI ships them at stock settings, so it would be just like a non-adjustable one at that point, but if you do ever need the adjustment, you have that option down the road, too.
if you go non-adjustable, and for some reason you need to adjust it later, you'll just end up having to buy an entirely new torque arm, which would be much more costly than if you had just spent the money on the adjustable one in the first place.
Old 12-12-2009, 09:28 PM
BandDirector Blk98ZM6's Avatar
I have the same question as the OP too.
WHY would you ever need an Ajd. TQ Arm? What mods and/or activities necessitate one?
Old 12-12-2009, 11:24 PM
^^^ lowering a car will throw off the pinion angle slightly. an adjustable torque arm will allow you to correct it.
Old 12-13-2009, 05:32 AM
Trunion King
bene's Avatar
My understanding is you would need adj T/A for drag racing so you can fine tune your suspension geometry therefore better 60' and ET.
Old 12-13-2009, 11:44 AM
aka adjusting/correcting the pinion angle
Old 12-13-2009, 11:49 AM
Trunion King
bene's Avatar
Right, therefore only if your car is dedicated drag only car, I'd buy something non-adj or just use the stock one.
Old 12-13-2009, 12:01 PM
yeah, I don't drag really so I saw no need for a $400 adjustable one. I like turning, and torque arms don't help that(well, there is one but it's $700+), so I just picked up a cheap one used. It does it's job, no wheel hop leaving around corners from a stop. I'm happy.
Old 12-13-2009, 01:37 PM
Badazz 97 TA's Avatar
you need an adjustable one for a lowered car. You need to correct the pinion angle. lots of bad advice in this thread. Pinion angle is important, and it isnt just for drag racing purposes. Having bad drivetrain geometry will effect the cars handling and performance.
Old 12-13-2009, 02:20 PM
How do you know where to set an Adj. TQ Arm? Do you need tools, or is it an "eyeball" type of thing? I'm lowered with Strano springs (1.2"), so what kind of problems is that causing with the pinion angle and how much improvement are we talking about with an Adj. TQ Arm?
Old 12-13-2009, 02:37 PM
You need one of these....
just some simple math
https://ls1tech.com/forums/suspensio...ion-angle.html
Old 12-13-2009, 05:57 PM
vatechguy3's Avatar
hoprfully sam will comment in here tomorrow regarding the use of his springs and the need for an adjustable tq arm.
tony
Old 12-13-2009, 07:09 PM
you don't "NEED" an adjustable torque arm in my opinion. is it a good idea? yes, but it's not absolutely required. i 100% dead hook on drag radials with a non adjustable torque arm, no wheel hop or tire spin at all. a 1.2" drop isn't going to put you at the point where the pinion angle is so far off that the U joints are going to bind.
yes it would be ideal, but if you don't have the money and just want something stronger than stock just to avoid snapping it and possibly damaging other things, non adjustable is fine. that's why i asked why the OP thought he needed one.
Old 12-13-2009, 07:18 PM
sixpack_2_go's Avatar
i would get adj.
just make sure you set your pinion angle correctly.
Spohn torque arms look really good.
Old 12-13-2009, 09:34 PM
MadMike 97 Z28's Avatar
Badazz 97 T/A is right. Its not about performance gains its about retaining correct geometry.
http://www.youtube.com/watch?v=UAQgLbhQ0uk
Old 12-13-2009, 09:43 PM
SIC LSX's Avatar
always buy adjustable! Anything else is a waste!
Quick Reply: non adjustable torque arm (-2)on a lowered car
