S60, 12 bolt, 9 inch, which uses less power
Old 12-12-2009, 08:36 AM
dr97z's Avatar
Default S60, 12 bolt, 9 inch, which uses less power
Which of the 3 aftermarke rear ends uses less power.
Old 12-12-2009, 08:42 AM
86MonteSS's Avatar
12 bolt
Old 12-12-2009, 04:23 PM
97camaross's Avatar
i just put in a 9 inch and im faster i noticed no loss in power at all
Old 12-12-2009, 04:35 PM
supermouse4's Avatar
12 bolt uses less power, but if you are choosing any of those rear ends, you shouldn't feel too much power loss.
Here is an article from Car Craft comparing each of these rear ends and power losses:
http://www.carcraft.com/techarticles...wap/index.html
Old 12-12-2009, 04:36 PM
EPP
EPP's Avatar
A lot of people get the same results, even with similar gear ratios. In theory it should slow you down, but sometimes theory doesn't get you too far... Bob
