Will the Vette DBW throttle body work with a 5.3 PCM and harness?
As the title says, I have a 2004 5.3 vortec engine and putting a LS1 intake on it and was wondering if the corvette drive by wire throttle body is a direct plug in to my 2004 5.3 Drive by wire harness?
I figure since the corvette throttle body is somewhat "mirrored" against the vortec pieces it could save me from clearance problems when adding the Fbody accessory brackets.
If it does plug in will it function normally or is there something different the PCM needs specifically for corvette programming?
Thanks!
Thanks!
