Random Cylinder Missfire Code
Everything is stock except for my cam and exhaust. The cam swap was very recent and it has been tuned. Started throwing Random Cylinder Missfire so I find a loose spark plug and wire. Tighten them and code goes away. Drive it for a couple of days no problems and sitting in traffic one night Check engine light comes on again, same code. What could it be this time?
thats the problem. yes it will reset itself if the problem doesnt happen within a certain amount of time. i have had the same thing for about 3 years now. if it shows a specific cylnder then i would worry. and it looks like your coming pretty close to your piston with that much lift on the exhaust i always heard .600 was about max with out cutting the pistons
Patrick G. spec'd the cam for me so I hope it is ok. I don't think he would have spec'd me a cam based on the info I gave him that would not work. Thanks for the help.
