center console removal and install 97-2002
Old 12-14-2009, 06:12 PM
johnp94's Avatar
Default center console removal and install 97-2002
Hello everyone. I removed 2 center consoles last week. Huge hassle, puting it back was even harder. I finally got it in but I scratched up my emergency break lever real bad. I will eventually be putting my friends custom painted center console in and I'm hoping there is a easier way. I unbolted all the nuts and screws, put the automatic shift back in to 2nd or 3rd. Tried to lift the console above the parking break lever and thats when the chaos starts. Is there an easier way. Thanks, John... It's on a Camaro
Old 12-15-2009, 08:59 AM
johnp94's Avatar
No emergency, but help!
Old 12-15-2009, 09:45 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
When you think the E-brake is all the way up, pull harder.
Old 12-15-2009, 10:00 AM
Slvr00Bird's Avatar
+1..
And if you're worried about scratching it, cover it with masking tape..
whytryz28's Avatar
Yeah couple times my ebrake didnt go much higher as to point over the dash but one time i pulled and heard a nasty noise and it was vertical, the adjuster sprocket thing came loose or something, was an easy fix.
Old 12-15-2009, 10:06 AM
johnp94's Avatar
With the front of console under dash and e brake all the way up, it is hard to lift the console over e brake. I can't swing it around to remove sideways. Thats what caused me the problem, lifting it over e brake when all the way up because it is wedged uder dash board. 93-96 you can remove the center CD holder to remove replace console. Seems like no breaks on the 97 and up. Trying to keep car in mint condition and e brake handle is messed up. I'm going to do this all over again when I get my car back. Gonna have to find easier way. I'm going to check into a dash removal post because I have to do that also. Just realized that might be my lucky break, removing dash. Thanks,John
Old 12-15-2009, 02:14 PM
Z28/2002's Avatar
If you are going to take the dash out anyway, it'll make putting the console in a breeze
Old 12-15-2009, 04:36 PM
99Bluz28's Avatar
I you use a long thin flat tip screwdriver and release the small ratcheting arm down the side of the e-brake pivot the lever will pull straight up with no effort, but make sure you block the tires first.
Old 12-16-2009, 03:55 PM
99pewterTA's Avatar
The console comes out in two pieces. Like was said make sure you release the ratchet arm on the e brake and it will pull straight up. If you have the first part of the console that includes the shifter housing/cupholder. If should be a breeze to get off. I have never had any problem in my ta except for the seatbelts getting in the way. I know you have a camaro and auto could be different but i doubt it.
Old 12-16-2009, 05:14 PM
johnp94's Avatar
Thanks for the response, When you say ratcheting arm coming up do you mean up to the brake position, or up and OFF. I was able to find a 98 aoutomatic at the junk yard tried taking complete dash out. No luck. Gonna start a new post on this issue. I've been taking the console off in two pieces but I still had that tough time getting it out. So can I take the ratcheting brake arm off. Thanks, John.
Old 12-17-2009, 08:09 AM
99pewterTA's Avatar
The whole arm does not come off. If you pull back on the handle pretty hard you will see the catch that grabs into the teeth that engages the parking brake. All you have to do is put the screw driver between that and the teeth and it will let you pull the handle way past where you can normally. Then you will need to lift up slowly from the rear and swing it up while pulling back slighly. It should come right out. If it doesn't try to focus on why not. It may require you to play around with the e brake a little bit.
Old 12-17-2009, 06:11 PM
johnp94's Avatar
Thanks, that sounds like it will be easier. John
Old 12-18-2009, 10:56 PM
slayerized6's Avatar
look up the shifter install on either ls1howto.com or installuniversity.com. both have detailed directions and pictures on how to remove the whole console
Old 12-23-2009, 06:25 PM
GoHardZ28's Avatar
This is exactly what I did, and it makes removing and installing 100 times easier. Just like he said put the e brake down, place a straight edge screw driver in between the cam and gear and pull it up as far as you want!! When your done place the e brake all the way down and pull up and it resests itself.
Old 12-27-2009, 12:16 PM
Nick D's Avatar
Yeah, they were very detailed and I was able to go through it with no questions because the quality of the write-ups were top notch. They have pics and walk ou through it step-by-step
Old 02-29-2012, 12:13 AM
Black02Bird's Avatar
+1!! Awesome tips.
Old 04-05-2012, 08:09 PM
johnp94's Avatar
I had to change the carpet in a different Camaro two weeks ago. The tip about using the screwdriver to wedge between the gear was a great help.
Old 04-05-2012, 08:19 PM
grazi's Avatar
sAme on a LT-1 Just removed mine the other day using this method was a piece of cake. At first I was like uh-oh then I started poking around and noticed that.
Quick Reply: center console removal and install 97-2002
