4L70E with stock C4 tailshaft / VSS question
Hello everyone,
I am installing a LS3 backed by a 4L70E into my 1990 Corvette. I am thinking about purchasing this adapter so I can bolt my factory 700R4 tailshaft onto the 4L70E and have a solution to mounting the C-Beam.
Adapter:
700r4 tailshaft:
4L70E:
The problem is that the 4L70E VSS won't be able to bolt onto the C4 tailshaft. I looked at the VSS from a 1996 Corvette and it looks like it will be able to work. Can anyone confirm if the 1996 4L60E VSS is a 40 pulse per driveshaft revolution like the 4L70E VSS is?
1996 C4 VSS:
Would I be able to move the 4L70E reluctor ring back to line it up with the new VSS? Would this cause any problems? I haven't had the chance to take the 4L70E's tailshaft housing off yet.
Thanks!
Adapter:
700r4 tailshaft:
4L70E:
1996 C4 VSS:
Thanks!
9 Second Club/LS1TECH Sponsor
Yes, the 96 4L60E is 40 PPR.
From what I can tell your plan looks good.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
http://advanceadapters.com/product/2322/50-0405.html
Matt
I'm curious to know if you can move the one thats on there..or if you have to buy a reluctor ring made to position\clamp such as the one with this similiar adaptor kit..
Matt
Matt
I talked to Jim at PATC today and he said that the reluctor should line up with my original tail housing if I use their adapter. I went ahead and ordered their adapter and hopefully the reluctor won't have to be moved.
