spacer question for skinnies
Old 12-15-2009, 05:32 PM
edzsilverss's Avatar
Default spacer question for skinnies
I just bought some draglite skinnies and never had to run spacers before. Which way do you mount them? The bigger side against the rotor or the wheel? Don't want my front wheel flying past me on the highway.
Old 12-17-2009, 04:05 PM
TTT anyone? They fit both ways but I want to make sure they are on right. Come on fellas, someone chime in. Discount or NTB have no idea.
Old 12-18-2009, 12:59 PM
PKC-Z71's Avatar
I put the bigger side against the rotor on mine, with no issues.
Old 12-18-2009, 01:08 PM
gixxer75094lt1's Avatar
i figured jus by looking at it people can tell , but anyways yes put the bigger side against the rotor.
Old 12-18-2009, 03:33 PM
alan2000T/A's Avatar
and make sure you keep it centered while tightening the bolts so as to not throw off the balance.
Did you put in longer ARP studs or are you using stock studs? If stock, I hope you aren't using more than a 5/16" spacer.
Old 12-22-2009, 03:46 PM
1qwkz's Avatar
which dtc you going through lol....? keep them centered bigger side against the hub, tq100pounds
