Pic request . OEM 19x12 / 18x10 C6 Z06 wheels on a 4th gen Camaro
09-10 Spider version or 06-08 split spoke version and with OEM 325/30 / 275/35 tires . Ive seen a couple pics of them on a 94 , but there werent many angles . I dont need to know how to make them fit , Im good there . I love either style , I just need more convincing a flat face wheel this big looks appropriate on a 4th gen Camaro .
Take no offense , but NO replica pics please , the offsets on nearly all of them set the wheel to far in the fender for my tastes . While the OEM's appear to sit absolutely perfect on the car . Plus they are just to heavy for me to consider .
Ive scoured the net , and cant find any 06-10 GM OEM Z06 wheels on a 4th gen , figured Id give hear a shot even though its proabably pointless .
http://www.gmhightechperformance.com...aro/index.html
also- on the replicas. the offsets are the same on some if you look. i was looking around...
18x9.5--40mm offset
19x12--59mm offset
but im with you on the replicas, they seem to be 2-3lbs heavier....
18x9.5--40mm offset
19x12--59mm offset
I've since seen a 98 locally with oems . The offsets on the oem c6 zo6 does not require a spacer . Stock 17x9 rim has a 50 mm offset , a 19x12 oem rim has a 59 mm offset , which sticks the wheel out about 1.5 more inches than stock . The rim sat flush with fender lip as well as the 18x10 front . The base c6 wheels suck in so much because the offset us quite a bit higher than the z06 . Before it's asked , the local car had 325 mm stock z tires and it was just hammer tubed and fender lips rolled .
they look good!i have a set of black 08 z06 wheels i'm debating on putting on my 2000 ta and i don't know whether to throw them on there or not with a spacer/without?i took them to a dealership to sell,but they arent having any luck selling them,and my ta needs wheels
Kore3.com sells the brackets for rear set up to run 98-02 rear brakes and flush strange or moser bearing ends . With or without parking brake . They just dont list it on their site , you have to order via phone or email . I was quoted 135 for the bracket not set up for a parking brake .
i actually own a set of oem c6z wheels now, got them cheap. they look awesome except for the fact the tire sizes arent very good. i have 285/35 front...and 305/30 rears....
as far as fitment...awesome! i dont think they stick out too far, i trimmed up the bumpstop but didnt remove it....YET! but i will. and ill find some better tires someday...
