rx7 7.0l v8 twin turbo build
hi guys made a bit of progress over the last few weeks here are some pics,
spec are
7.0l
all steel internals,
cnc flowed after market heads,
two gt35 turbos
emerald new type ecu with turbo control,(and traction i hope !!)
will post some more as stuff when i get time to do more
spec are
7.0l
two gt35 turbos
Regardless though I would like to hear more about the setup I am planning on custom mounting a viper diff in my FC once I start breaking the stock rear end.
hi guys a couple of updates,(will post some more pics soon),i am about to build the motor for it but i am de stroking it from 4.125 down to 4.00" to allow for better pistons, et performance 255cc heads,238,238.598cam,fast 90 intake,twin gt35s,all headers and exhaust made by myself,twin plate clutch,emerald ecu with 3 maps,and boost control against throttle angle and revs,oh and traction control !!
http://www.emeraldm3d.com/
this is there web site but not much info on it at the moment,i ambuilding the guys who own emerald another rx7 twin turbo (doing it at the same time as mine), i have used there ecus for years on ls motors,and they are working on one which will do more boost control,they are very simple to use and do everything you need, if you want any more info you can ask them or i will find out for you, cheers craig
