Whats it worth: 98 T/A
1998 Pontiac Firebird Trans Am
5.7 Liter LS1 V8 Engine
T56 6-speed Manual Transmission
Black Exterior/ Charcoal Interior
Power Windows, Power Locks, Power Mirrors, 6 Way Power Drivers Seat, 4 Way Power
Passenger Seat, ABS, TCS, T-tops
Engine:
- Raised WS6 lower air box
- K&N Filter
- SLP Lid
- SLP 85mm MAF
- SLP Smooth Bellows
- Ported Stock Throttle Body
- Weiand/Lingenfelter Intake Manifold (Ported)
- #243 Heads (LS6) (taken off a 2001 Z06)
- 99+ LS1 Valve Covers, Red powder coated
- 7.425” Comp Cams Chromoly Pushrods
- METCO Crankcase Breather
- Pacesetter Long Tube Headers
- 3” TSP Catted Y-pipe
- 3” Adjustable Borla Catback Exhaust (Wide open plate)
- !AIR
- !EGR
- !PCV
- !CAGS
- !VATS
- MSD 8.5mm Wires
- NGK TR55 Spark Plugs
- 3.73 Rear End Gears
- “****” Mail Order Tune
Transmission
- LS7 Clutch Kit (LS7 Clutch, LS2 Flywheel)
- 01-02 Updated GM Slave Cylinder
- RAM Adjustable Master Cylinder
- Tick Remote Speedbleeder
- Hurst Billet Shifter
- WS6 Store Short Stick
- C6 Corvette Shift ****
Interior
- Aeroforce Dual Interceptor Scan Gauges
- Full length, dual gauge Pod
- LED Interior Lights (Dome and Map)
Suspension
- Prothane Poly Motor Mounts
- Energy Suspension Transmission Mount
- Energy Suspension Torque Arm Mount
- 17” Eagle Alloy Wheels
- 245/45/R17 Goodyear Eagle F1 All Season Tires
Braking
- Rotoworks Drilled and Slotted Rotors
- Hawk HPS Brake Pads
- Earl’s Solo Bleeders
Audio
- Alpine CDA-9811 Head Unit
Body
- Aftermarket WS6 Hood
- 30th Anniversary “Trans Am” Tail Light Filler Panel
- OEM White “Trans Am” Door Emblems
- Blacked-out DRL’s
- Blacked-out side markers (bulbs removed)
- LED Rear License Plate Bulb
- Shaved door trim
- HID Low Beams (Euro Lamps sealed beam conversion kit) (10,000K)
- HID Fog lights (10,000K)
- 15% Tints
Engine:
- K&N Filter
- SLP Lid
- SLP 85mm MAF
- !AIR
- !EGR
- !PCV
- !CAGS
- !VATS
- MSD 8.5mm Wires
Transmission
Interior
Suspension
Braking
Audio
Body
- Blacked-out DRL’s
- Shaved door trim
- 15% Tints
