Fueling & Injection - Anyone know of a write up to use to swap fuel pumps?
01 Trans-Am WS6
12-21-2009, 05:32 PM
My fuel pump took a shit on me, needs replacing. Is there any write up I can use to do the job myself? I found this:
http://www.gonicd.com/intankinstall/intankpumpinstall.html
Is this pretty much the same for all brand fuel pumps?
Also does anyone have any info on this pump from Summit?
http://www.summitracing.com/parts/GRN-GM722-2/
koolaid_kid
12-21-2009, 09:01 PM
Umm, the sticky at the top of this section?
There are several things wrong with that writeup, IMHO.
The Granatelli is a repackaged marked-up Walbro. Either buy a real Walbro (most likely for less) or buy a Racetronix kit.
99Zeeeeeeeeee28
12-21-2009, 09:37 PM
That's the write up I used when mine went. It's pretty straight forward, just make sure you are very careful when cutting the trap door so you don't end up cutting right through to the tank. Oh and go with the racetronix kit. It'll make things a LOT easier.
dlandsvZ28
12-21-2009, 10:44 PM
Find a Harbor Freight and get this tool to make the cut. It cuts a perfect straight line through the metal like butter.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=97636
01 Trans-Am WS6
12-22-2009, 12:29 AM
The one from Summit is $125 so that doesnt seem too bad. And thanks for the heads up on that tool, for $7 I might aswell pick it up!
NicD
12-22-2009, 07:59 AM
Do tell...
01 Trans-Am WS6
12-24-2009, 12:01 AM
Do tell...
?? wondering this myself
koolaid_kid
12-24-2009, 07:32 AM
Not trying to cause trouble, but here's a couple:
Don't use fuel injection hose. It is not qualified as fuel submersible. If you choose rubber hose versus the flexhose, use SAE J30R10 hose, which is also available from ape. It is fully qualified fuel submersible, although there have been reports of Ethanol compatibility softening it (even with E10-15, which is what is used up here in Indiana). Also, using the rubber hose may lead to kinking during assembly, so be very careful to avoid this.
If you use the flexhose, the worm clamps will work just fine.
The link to ape is excellent, btw, since they carry all the things you should need for the install.
I strongly suggest using care when removing the retaining ring. Steel upon steel "...use a large flathead screwdriver and hammer and pound the retaining ring off..." can cause sparks. Sparks + fuel vapor = potential explosion. IIRC, I used a large pipe wrench or channel locks, which required no pounding (it's been a while).
Finally, if you care about the bucket integrity, or you tend to run your tank at low levels, you may wish to consider the Racetronix pump, which is a "plug n play" item.
All in all, it is a good writeup, but caution should always be taken.
NicD
12-24-2009, 12:00 PM
This was mentioned, thus the link to APE to purchase the other type of hose so you don't have to worry about fuel submissible hose or splits over time from rubber softening up.
Uh, this was mentioned as well.
RsSean
12-24-2009, 01:23 PM
If you can wait a few days I am will make a really nice write up, cause I will be doing mine with a racetronics one. I am doing mine by droppin the tank since the rear end will be out.
dlandsvZ28
12-24-2009, 01:32 PM
For the small additional cost of the Racetronix kit over the Summit version I think the OP should go Racetronix instead.
To the OP - the Racetronix kit includes the wire kit from pump to alternator which makes a great difference in voltage to the pump over stock making the Racrtronix kit the ideal solution if you plan to mod or upgrade your system later. The Racetroxic kit will handle up to about 550 rwhp.
Not sure if the Summit kit will do that unless you install the Casper wiring kit along with the new Summit pump. But if you do that - the total difference in cost between both is very little making the Racetroxic kit the preferred choice.
01 Trans-Am WS6
12-26-2009, 10:35 PM
Hmm some good info, I am going to check out a Racetronix kit now!
Also guys another question...do I need a fuel pump and fuel pump only? Or is there more to it?
dlandsvZ28
12-26-2009, 10:51 PM
The kit includes everything - even a paperclip for the installation. The kit is a 'true' plug and play kit.
Their site shows the kit and items included. Link below includes a pic of the kit but from Thunder Racing's site.
http://www.thunderracing.com/catalog/?action=mshop&mid=88&sid=260
It appears that the kit is cheaper now too, compared to when I got one (about 4 years ago). My kit is for a 98. It currently supports an ATI D1SC Procharged 347 making 565 to the wheel on a Mustang dyno with 60 lb Mototron injectors. Fuel pressure is consistent 58 lbs.
koolaid_kid
12-27-2009, 09:09 AM
The Walbro pump draws ~9 amps, vs. the stock pump's ~5 amps. The stock wiring is marginal for the current draw of the stock pump, and should really be upgraded for the increased current draw of the Walbro. The Racetronix harness is a very well designed and implemented piece.
02BlkZ28
01-03-2010, 07:35 PM
I got a bit of two sense on this...I bought the fuel pump from summit a few months back and well lets just say it dont hook up like the stock one does! My stock pump had two fuel lines the man one the big hose and then the tiny one that hooked up to the pump and went to the sock. The new pump from summit has a whole where the little hose would hook up but no fitting to hook the hose up to....So my question would be is the lil hose needed or what is need to make this work??
01 Trans-Am WS6
01-04-2010, 07:25 PM
Hey, here is an update, can anyone help me here?
I am looking at Racetronix pump from Thunder Racing. Here is the link, it is the 4th product down $150:
http://www.thunderracing.com/catalog/?action=vshop&vid=3&pcid=165
I see right below that one, there is a kit that includes even more (wire harness) and it is $209.
If I pick up just the $150 unit, it says it is pretty much plug and play. I don't think I need the other unit as I do not plan on doing anymore motor work for the time being, also my stock unit held up for a while so I don't see why the other wouldent. Is the wireing harness THAT big of a deal? Thanks for any help, I am just still confused but would like to get this resolved soon. Thank you!
Also does anyone know of any same or similar pumps from different vendors for cheaper than that besides Summit?
Racetronix
01-04-2010, 08:27 PM
It all comes down to the HP you want to support and your motor build (BSFC). ???
01 Trans-Am WS6
01-04-2010, 10:22 PM
My car puts down 407RWHP..Its a cam only car and will remain like that for a while.
01 Trans-Am WS6
01-05-2010, 10:56 AM
Will just the pump work? (no harness)
