Removing Main Caps???
Old 12-21-2009, 06:34 PM
RENE'S RAGE's Avatar
Default Removing Main Caps???
What's the best and safest way to remove the main caps?
All the bolts are out.
Old 12-21-2009, 07:10 PM
...with cheese.
Armageddon's Avatar
Rubber Mallet.
Maintain a steady upward pressure with your hand like you were trying to pull it off anyway. Take a rubber mallet and gently pop it on the ends. Make sure not to drop it when it comes loose.
You can bump it on the sides and get it to wiggle also. Once it starts to wiggle you can just work it off without the hammer.
Old 12-21-2009, 09:33 PM
studderin's Avatar
make sure you have ther side bolts out. I have a soft jaw kanit twist clamp I use as a spot to use some slight upward action with a soft hammer. You can get fancy with some brass or wood, on the bay to bay breathing window pockets. To pry up gently, if ther really stuck.
I think GM has a Jtool for this. And kent more, and goldsing, have a puller too. Looks like a corkswrew
https://ls1tech.com/forums/tools-fab...oval-tool.html
check E ba y for a LS1 maincap tool........
Old 12-22-2009, 04:10 AM
427's Avatar
You can take two long 3/8 extensions and start them into the bolt holes, then squeeze them together, wiggle and pull up. If you will be working with very many buy the Thompson automotive tool it's well designed and easy to use.
Kurt
Old 12-22-2009, 05:32 AM
Thanks guys.
Happy Hoildays.
Old 12-22-2009, 10:09 AM
01ssreda4's Avatar
I just put a big prybar under them and gave a quick tap and they pop right loose. No special tool needed.
Old 10-15-2016, 03:51 PM
pmisaac24's Avatar
Default main caps
Thanks for tip on removing side bolts. I can stop hammering on it and using slide hammer. Dah!!! Not the best mechanic.
Old 10-20-2016, 01:42 PM
Forcefed86's Avatar
Can also take the long main bolts 90% out of the hole, then squeeze and rock back and fourth while pulling up.
Old 10-20-2016, 09:51 PM
MuhThugga's Avatar
Oh lord.
That's almost as bad as the guy who hooked a come-along to his camshaft because he never held the lifters up with dowels.
Old 10-21-2016, 10:48 AM
svslow's Avatar
Better put some gloves on too, those thing are pretty sharp around the edges.
Quick Reply: Removing Main Caps???
