Need help!
Old 12-22-2009, 02:53 PM
Bo's 98 TA's Avatar
Exclamation Need help!
I put some long tubes on my trans am and now sometimes when I try to strat my car it wont, it smells like its flooded, if I pull the relay that goes to the fuel pump and crank it over it will start then I can put the relay back in and its fine, what can I do all the wires are plugged in.
Old 12-22-2009, 03:06 PM
Lopoetve's Avatar
did you get it tuned?
edit: your sig implies yes?
edit2: Leaking injector?
Old 12-22-2009, 03:19 PM
Bo's 98 TA's Avatar
Havent got it tuned since the headers, tune was before them, and I will check the injectors, thanks for the help.
Old 12-22-2009, 03:37 PM
...with cheese.
Armageddon's Avatar
Change your plugs.
Old 12-22-2009, 04:22 PM
Bo's 98 TA's Avatar
plugs are new!
Old 12-22-2009, 05:53 PM
MTN_Z's Avatar
No check engine light or anything? I started having issues because I routed the fuel pump harness incorrectly and the header burned the wire. Check all the wires and make sure all connectors are plugged in. You never know what you might have missed.
Old 12-23-2009, 10:08 AM
Bo's 98 TA's Avatar
I have a check engine light on!
Old 12-23-2009, 02:15 PM
1qwkz's Avatar
woahhh
Old 12-23-2009, 02:18 PM
7th Darkness's Avatar
Must be a code ID 10T... if I was guessing.
Old 12-23-2009, 02:30 PM
MTN_Z's Avatar
....yeah I would start with checking out that code.
Old 12-23-2009, 03:07 PM
98TAjwh's Avatar
Originally Posted by 7th darkness
must be a code id 10t... If i was guessing.
hahaaa
Old 12-23-2009, 03:53 PM
Bo's 98 TA's Avatar
Hahahaha funny **** off! if your not gonna help then dont say any thing find somewhere else to post.
Old 12-23-2009, 11:01 PM
mcalestermatt's Avatar
ta looks good in the sig bo
Old 12-24-2009, 07:26 AM
First of all I was joking and second of all you hardly give any information to help you with.
All I got was that you installed long tubes... and now you are having trouble starting your car. Not to sure what the relay has to do with any thing, but ok.
My best bet would be that your are throwing a code for your 02 sensors. You will need to upgrade to the vette 02's. I had to do the same thing, same problem.
Old 12-24-2009, 01:43 PM
Bo's 98 TA's Avatar
ok thanks, and when I pull the relay it stops the fuel pump and it gets all the gas out of it, cause its flooded. The code that shows is the Ho2s wich is that its getting to much fuel getting it retuned next week. And sorry for being an ***. Thanks to everyone for the help.
Old 01-07-2010, 05:34 PM
Bo's 98 TA's Avatar
I got the Vette o2's and my problem is fixed. Car runs great now im gonna order my cam and stall.Thanks guys
Old 01-07-2010, 07:26 PM
DarkJuggalo's Avatar
nice! glad that worked for you i noticed a huge difference with my LTs, great investment
sound is amazing too!
Old 01-07-2010, 10:53 PM
Bo's 98 TA's Avatar
thanx I love the way it sounds and runs better.Now I cant wait till I get the cam
