What goes Here?
What goes Here?
I just bought an LM7, not sure what year it is, and am in need of some help figuring some things out. The person I bought it from said it was either from a '99 or 2000 Yukon, the crank sensor is in the back, if this helps figuring out the year. I need help figuring out what goes here?
What are the tubes running through the bottom of the intake called? I have to replace them with the singles that run straight across so that I can mount the LS1 intake.
first pic should be the alternator bracket holes,
second pic is the coolant crossover lines for the heads, the coolant lines that are on there will work just fine with the ls1 intake (and ls6 with some modifications)
