PCM connectors
Old 12-22-2009, 10:26 PM
the450r's Avatar
Default PCM connectors
Im doing my own wiring and i was wanting to eliminate the wires for the down stream O2, Evap, ect. The control and signal wires that run to the PCM connectors. Are the rubber oem plugs for the terminals available. Or do you leave the wire(s) in there and cut them short and tape them off?
thanks
Old 12-22-2009, 11:03 PM
sawzall wielding director
G-Body's Avatar
You could leave the wires in and tape them off. But most people tend to fully remove them and then put silicone in the empty holes.
Old 12-23-2009, 05:34 AM
poconojoe's Avatar
You can only reseal the membrane on the top of connector, since unlike other connectors, that will be missing the terminals on both sides on the connectors, the PCM will always have a terminal, so you can't plug the hole in the harness side, since you will no longer be able able to put the plug in.
Quick Reply: PCM connectors
