Bad PCM?
Old 12-23-2009, 10:04 AM
koji777's Avatar
Default Bad PCM?
GUys, is there any way to check the PCM to see if it is bad? If I can tie into it with HP Tuners, does that insenuate that it's good?
Reason for my question is as follows:
I finishing my KYTP front mount build and was going to fire the car up. While turning the car over, injector fuses out... to catch oil psi, the brass braided ground line from the block to the chassis got extremely hot. I assumed that the starter was going bad and purchased a new one. I asked them why the ground strap would get so hot... they told me because the primary ground from the batery was bad. Since i had to change the stock k member to a BMR, I found that where I attached the primary ground was not good. I moved it to the chassis and now everything is fine. I reinstalled the injector fuses. The car turns over, but I am not getting any fuel from the injectors. I am getting fuel to the rail however. I replaced the ignition relay, still no injectors.
Any help deeply apreciated.
Mark
Old 12-23-2009, 10:21 AM
Frost's Avatar
they are run by the same +12 that drives the coils... Turn your key on and unplug an injector; one of the two sides should read +12
Old 12-23-2009, 10:30 AM
koji777's Avatar
With the key on I have 8 volts on one side of the connector and 11 volts on the other.
Any ideas?
Old 12-23-2009, 11:17 AM
Doc
Doc's Avatar
What kind of vehicle is this in?
Old 12-23-2009, 11:43 AM
koji777's Avatar
2000 camaro ss
Old 12-23-2009, 11:47 AM
koji777's Avatar
Here is the latest.
I've got spark, I've got injector pulse width activity as indicated by HP TUners. I've changed the ignition relay, both injector fuses are good. I see about 180 rpm on HP Tuners scanner while turning it over.
Any help DEEPLY appreciated.
Mark
Old 12-23-2009, 12:04 PM
Doc
Doc's Avatar
Do you have a crank position signal?
Old 12-23-2009, 12:13 PM
koji777's Avatar
I'm showing 130 +/- rpms' on HP Tuners scanner while I crank it
Old 12-23-2009, 12:17 PM
koji777's Avatar
Just used a NOID light... seems that the injectors are actuating. Fuel pump primes the rails.... maybe she is not running during the crank sequence...... and reccommendations?
Old 12-23-2009, 02:23 PM
Frost's Avatar
base tune solid for the injectors that you are using?
Old 12-23-2009, 02:42 PM
koji777's Avatar
Yes sir
