Nitrous and Low CR, come inside.....
I was just jotting down some ideas for a project car and started thinking.....
Eventually I would like to do a Turbo'd LT1 backed by a TH350 in a stripped down F body. I am still thinking about maybe a 5.3 but for now the LT1 will be MUCH cheaper to do.
My plans are now to strip the car and replace all the internals with forged units, put a cam in it (CC306 used), home port and polish the heads and the intake and then spray around a 200 shot on it. Now, I already have almost everything I need for a nitrous kit, and since I am on a budget for now, I'd like to stay with spray since it would be the cheapest route.
But, if I could run a Low CR piston now, when it would come time to build a turbo kit for it, I wouldn't have to do anything to the bottom end and just have to change out the cam.
I have no interest in NA numbers, I know that the low CR will affect me NA anyways. This car is going to be a strip car and when its going, the pedal will be to the floor and it will have some go fast juice going through the motor.
I just want to know if the low CR will be ok for nitrous.
Thanks guys
Justin
Thanks guys
Justin
It will be just fine. My only concern would be that if you go with a dished piston you obviously won't have as much material on top of the piston and it won't handle the heat as well. On a 200 shot you shouldn't have any problems though as long as you don't go crazy with the timing.
