anyone make Homemade Solid motor mounts?
Solid mounts like this ? The way I did it was , install the plates to the motor then install the motor and trans into the car level it and set the height while it is sitting on a floor jack . when you got the clearance where you want it then measure for the pedistal . When you get the pedistal made bolt it to the car , set the motor down on it re-adjust if necessary when it's exactly where you want it tack weld it in a few places , remove and weld it up . Stan
