LS2 LS7 lifter failure
Old 12-23-2009, 11:04 PM
B Layton's Avatar
Default LS2 LS7 lifter failure
I had a LS7 lifter fail it wiped out my cam, the shop pulled the heads cam and lifter said the the lifter sleeve guide was OK no damage. installed new cam and Comp Cam lifters. I have two questions what would cause the lifter to fail and now the engine makes sewing machine noise from the side of the engine that had the failure. Oh and the water pump went bad and the rear main seal is out after the repairs.
Old 12-23-2009, 11:11 PM
01wssick's Avatar
wow bump. i wanna know bout the ls7 lifter fail too. thats what i planned on getting.
Old 12-23-2009, 11:16 PM
silverz28camaro's Avatar
how many miles on the cam setup? springs and pushrod lenght all correct and in good condition? I run ls7's in my ls2, no issues so fat, have about 6,000 miles on them.
Old 12-23-2009, 11:40 PM
B Layton's Avatar
1750 miles, compcam Comp Cams XE-R lobed grind - 237/242 duration @ .050, .603/.609 lift, 112 LSA, Heads, 7.4" Chromemoly Pushrods, L92 Rocker Arms, Pedestals & Bolts, PRC
Gold Double Valvesprings /w Titanium Retainers locks/seals/bases, should all been new
Old 12-24-2009, 01:32 AM
lets see some pics
Old 12-24-2009, 03:59 PM
B Layton's Avatar
Default LS2 LS7 Failure
Here is a picture, I think?
Old 12-28-2009, 09:00 PM
93blcZ28's Avatar
Damn i hope my ls7's hold up runnin strong still after about 1500miles
Old 12-28-2009, 10:03 PM
SOMbitch's Avatar
Too much preload or not enough???? How many miles? Weak springs causing valve float will beat the crap out of a lifter too. Just curious what size cam?
Old 12-29-2009, 06:55 PM
MattxFatal's Avatar
Yeah...
Old 12-29-2009, 07:36 PM
69LT1Bird's Avatar
Where did you get those lifters. Those look like old first generation LS1 lifters that have no support on the top and bottom of the rollers.
Take a look at the attached pic. Your looks like the one on the right which is an old design. The new LS7 replacements are the ones on the left. Plus you probably wouldn't be using 7.400 pushrods.
Old 12-29-2009, 08:49 PM
Rob@ChampionMotors's Avatar
If you closer the his pic it's the newer supported design. The metal has broken off.
Rob.
Old 12-30-2009, 03:16 PM
blue99fbody's Avatar
ms3?.
Old 01-04-2010, 11:21 PM
B Layton's Avatar
Got the car back new cam is Comp Cams 281LLR H13 231/247 duration @ 0.50, .617/.624, 113LSA with Comp Cams lifters, I hope this will last longer. the same springs were used so if its a weak spring, I guess we will see.
Quick Reply: LS2 LS7 lifter failure
