Oil fill tube removal. Am I stupid?
Old 12-24-2009, 11:47 PM
faster_n_you98's Avatar
Default Oil fill tube removal. Am I stupid?
I can't twist, pry, or pop it off... How the hell you I remove it. Its not in the haynes manual either...
Thanks ahead of time
Old 12-25-2009, 08:58 AM
01ssreda4's Avatar
I tried this too when painting my valve covers. I said the hell with it and just taped them up and left them on bc they were being such a pain in the ***.
Old 12-25-2009, 10:03 AM
jrpimp00's Avatar
push down slightly and turn to the left about 160 degrees
Old 12-25-2009, 10:21 AM
t/a98's Avatar
what he said, it sucks, i pried mine off, but it screwed it up a little, when you get it off you can see exactly how to pull it off and put it back on
Old 12-25-2009, 10:30 AM
elias_799's Avatar
if you are removing it to install a breather do not do it !!! i removed my filler neck and installed the breather, and the breather kept dripping a little oil on the exhaust manifold because it is on an angle. if you keep the filler neck the breather will be straight and no leaks.
Old 12-25-2009, 11:36 PM
Very Helpful hint, I actually was planning on it for that very reason!
Thanks to all that chimed in. I just wanted to double check before i break somethin.
Quick Reply: Oil fill tube removal. Am I stupid?
