General LSX Automobile Discussion - E-Bay auction Camaro
SHORTZ A KILLA
12-25-2009, 09:42 PM
Hi-wondering if anybody knows the history of this car, claims to have a transplanted LS7 w/ 630 Rwhp. I'm thinking about bidding but the seller says he doesn't know too much about the car-not original owner. If it's straight has alot of potential for the right price, waiting on a response from a laundry list of questions I sent the seller.
Thanks :usa:
http://cgi.ebay.com/ebaymotors/2000-CAMARO-SS-w-2006-Corvette-ZO6-ls7-swap_W0QQitemZ160389675696QQcmdZViewItemQQptZUS_Ca rs_Trucks?hash=item2557f83ab0
cad2k3
12-25-2009, 09:44 PM
thats not an ls7 maybe a ls6
SHORTZ A KILLA
12-25-2009, 09:51 PM
Hmmm I didn't see any dry sump oil system either, is that how u know? but he's quoting HP #s of 630! I requested a Dyno sheet
Armageddon
12-25-2009, 10:06 PM
Scam, stay far away.
99FormulaM6
12-25-2009, 10:16 PM
that does not look like a LS1 fuel rail crossover ... could be a LS7
SHORTZ A KILLA
yeah I sensed that too! especially "I have nothing to hide" statement :turd:
Thanks
SHORTZ A KILLA
12-25-2009, 10:18 PM
yeah but where's the dry sump set-up every F-bODY Swap I've seen using LS7 motor had it :confused:
99FormulaM6
12-25-2009, 10:19 PM
i would not call it a scam right away. The guy definitely can not write a for sale ad, but a scam..? You might get that dyno sheet and more pics and a video, or call the guy and talk to him if you are really interested.
SHORTZ A KILLA
12-25-2009, 10:28 PM
Yeah I already requested lots of 411 from him
It's a scam, intake looks to be an LS6 or Vette LS1 non-EGR intake painted gray along with a stock 3 bolt 75mm throttle body(listed as 92mm LOL). If it really was an LS7 that intake wouldnt even fit those heads.
I reported it, hopefully the listing will go away.
82cetuner
12-25-2009, 11:01 PM
just cause it is a LS7 does not mean it has to be a dry sump system. all you have to do is swap the oil pan windage try and oil pickup. you can turn any LS engine into a dry sump with using a LS7 oil pan.
Get pictures of the intake and T/B and Fuel Rails. I would definetly get a dyno sheet before I pay for 630hp worth of car. Even with all that proof you could get swindled just the nature of online buying. if hes a good scammer he will look for other peoples dyno sheets.
Good luck
82cetuner
12-25-2009, 11:02 PM
Yup 4150 is right, LS7s would not of had a 3 bolt throttlebody. I am at work so I could not see the picture.
elias_799
12-25-2009, 11:28 PM
that does not look like an ls7 intake manifold to me
sway99bird
12-26-2009, 01:29 AM
Don't do it unless he has proof and that dosen't look like a LS7
araber89
12-26-2009, 02:33 AM
um... ya I am going to say its not a LS7 here is a picture of an LS7. A few things:
1. this one has an electric throttle body (ETC)
2. Look at the location of the alternator compared to his
3. Look where his power steering resivor is compared to the LS7
4. Finally look where it says LS7 on the FRC's of the LS7 and you don't see that in his picture.
http://paceperformance.com/ProductImages/manufacturer/gm/images/17802397.gif
Also it seems he has a SLP intake manifold. I know I have seen one like that before but I can't seem to find it on the web anywhere...
therobman
12-26-2009, 09:07 AM
its not an ls7 easy to spot
eseibel67
12-26-2009, 09:21 AM
I wouldn't give this ad a second look. There is a wire hanging over the PS pulley, going to be cut though when you drive over the first bump in the road. If it's too much trouble to tie that off for the picture in the ad, how about everything you can't see?
That tells the whole story that this is a pile of shit.
Ryan33187
12-26-2009, 12:45 PM
Didn't know our car had cams... plural...
Also looks like the lid is cracked
SHORTZ A KILLA
12-26-2009, 06:53 PM
oH well -THANKS TO ALL -i won't be looking at this one to buy :usa:
justin455
12-27-2009, 06:51 AM
my first instinct told me that one wouldn't swap in an LS7 and be so proud of it as he is only to retrofit C5 FRCs instead of keeping the much cooler ones already on it. Glad you're not going after this one.
bamalt1
12-27-2009, 06:46 PM
Who would run 4.80s with an auto anyway? That's a ton of gear even for an m6. Did he even answer any of your questions?
slayerized6
01-06-2010, 12:06 AM
-guy has 0 feedback
-did ls7'd ever come with black fuel rail covers?
-that shit looks like a ls1/ls6. definitely not an ls7
itsslow98
01-06-2010, 01:04 AM
im gonna take the guys word for it, seems very knowledgeable about the car. im gonna bid on it and see if i can get it. JK
badss_02
01-06-2010, 01:20 AM
First off why does the motor have to have the powersteering pump and alternator in stock vette location if its a camaro swap??? That is not an ls7 but those are not things i would go by, You can use stock brackets and relocate your alternator and ps pump... Looks better on bottom anyways.
JonCR96Z
01-06-2010, 01:21 AM
Wow, it surprises me how many people in this thread know so little about LSx motors.
Maybe if we can get one more guy to verify if this is an LS7 or not, then we'll be set.
archerandsons
01-07-2010, 03:34 PM
ls7 intake is not so rounded and is wider.... ls1/ls6 intake if i say so myself.
ls7's dont have egr headers like that.... those are ls1 headers!
ls1 tb and maf.... ls7 is electronic different maf
need i go on!!
SCAM!
JonCR96Z
01-07-2010, 03:52 PM
need i go on!!
SCAM!
Another stupid and pointless post.
Ls7 don't have EGR? What the fuck does that have to do with anything. If you were to put an LS7 in an F-body you have to use F-body headers. Half of which have EGR ports. True, you should be using a bigger race header, but you don't have to.
LS1 MAF. So what? You can use any MAF you want. Again it might not be optimal, but that's still irrelevant.
LS1/LS6 intake, well that is obvious by looking at the TB. No need to look at the runner shape or the fuel lines. Which means that they are cathedral port heads. But guess what, those heads will bolt onto an LS7 short block. He says forged LS7 motor, maybe he just means bottom end.
The only thing that he says that can really be proven wrong, by looking at the evidence that we have, is the 92mm TB. I'm sure it probably doesn't have all that it says, but it can't dis proven by those pics.
It looks to have patriot heads and an LS6 intake so it could still be worth $8500, but anyone considering this should not expect anything more.
01ssreda4
01-07-2010, 04:46 PM
Obviously this guy is an idiot, and you^^^ sticking up for him means maybe you and him are the same person :suspiciou Either way, the car looks like a throwed together piece of shit.
Have a nice day :D
The Misfit
01-11-2010, 10:46 PM
I ran across this posted on craigslist here in Dallas a few weeks ago wile I was looking for an F-body. He claimed he got it for his son but it had too much power for a 17 year old . It seemed kinda odd to me.
Jeff Smith
01-13-2010, 08:15 PM
Look like that car park in the POUNDs :::)))
