how many ft lbs of tq for draglites on 99 fbody
Old 12-26-2009, 01:29 AM
edzsilverss's Avatar
Default how many ft lbs of tq for draglites on 99 fbody
I've already searched with no luck. How many pounds of tq do we use for draglites?
Old 12-27-2009, 11:45 AM
ls2 bait's Avatar
weld recommends 75. i generally do 80. and i check them every pass.
Old 12-27-2009, 02:28 PM
Camaro396's Avatar
I do 80ft lbs.
Old 12-27-2009, 03:28 PM
MYSTIC-1SC's Avatar
sorry to change to wheel brand, but how bout the torque specs for billet specialties street lites on my f-body. Currently i torque them to factory torque specs is that fine.
Old 12-27-2009, 07:04 PM
Originally Posted by Camaro396
I do 80ft lbs.
I bought a tq wrench and 75-80 seems way to loose. I had read that before but it seems like they would fall off lol. I went with 90 since it's my daily driver.
Old 12-27-2009, 07:26 PM
therobman's Avatar
i do 90-100
Old 12-27-2009, 07:28 PM
MYSTIC-1SC's Avatar
yea same thing here. i do 100
Old 12-28-2009, 09:39 AM
wheelczar's Avatar
It is not the style of wheel that creates the torque specs, it is the thread pitch of the stud. The wheel does not make a difference. Here is a run down by thread pitch for torque specs.
12mm 95 ft. lbs
14x1.5mm 110 ft. lbs
14x2.0mm 140 ft. lbs
7/16 75 to 85 ft. lbs
1/2 85 to 95 ft. lbs
9/16 105 to 115 ft. lbs
5/8 135 to 145 ft. lbs
Hope this helps.
Old 12-29-2009, 09:01 PM
Camaro396's Avatar
12mm 95 ft. lbs
Hope this helps.
Did not know that, learn something new every day. Thanks Kyle, or Scott? Whichever one is posting
Old 12-29-2009, 10:39 PM
12mm 95 ft. lbs
Hope this helps.
My new studs are M12-1.50 12.73 mm so 95 it shall be. Is that correct? lol
Old 12-30-2009, 08:37 AM
wheelczar's Avatar
Nope neither one. I sent you back a PM on rim width.
Old 12-30-2009, 09:23 AM
Did you send me a pm? I'm confused here lol. I didn't get one if so. The wheels are 16 x 8 and 15 x 3 if you are talking to me btw. Is 95 correct for my wheel studs?
Old 12-30-2009, 10:21 AM
wheelczar's Avatar
12mmx1.5 uses 95 ft. lbs of torque. Check the torque for the first 25 miles and then again at 50, if torque is maintained you should be good to go, if not check your lug seat area on the wheel for any problems.
Old 12-30-2009, 11:51 PM
DriftR's Avatar
I think the torque spec for the wheels is in the owners manual?
from Memory:
M12 x 1.5 = 100ft lbs (Trans Am)
M14 x 1.5 = 140ft lbs (Silverado)
Old 12-31-2009, 11:43 AM
from Memory:
It sure does say that. The stock studs are 12mm also. I'll just keep an eye on them I guess.
