Can I Hook?
Can I Hook?
I currently am running 27-10.5-16 M/T ET streets and running 1.75-1.90 60ft.
I am considering going to M/T drag radials 295-55-15 on 10" rims. Car is a M6, 4.10 gears, N2o, cam, heads, STREET TWIN clutch. 530 RWHP. Suspension mods are: BMR torque arm, Ebach drag springs w air bag, 9" rear, Siphon cont. arms with lowering bracket, CE rear shocks, battery relocated in trunk. 3420lbs. Im I wasting my time or can I hook. If not I will just put the biggest M/T ET streets on the new 10" rims and be done with it. I wanted to run the radials if it will work because the fronts are M/T radial skinneys (Sportsman S/R). Thanks guys.
