what Heads fit the LQ4 and LQ9 blocks?
Old 12-26-2009, 03:14 PM
palaSS's Avatar
Default what Heads fit the LQ4 and LQ9 blocks?
im doing a swap and im trynig to gather all part and price them. IIRC the 317are stock.
I wanna stock LQ block and some good heads to get ported, MS3 cam. To let you know, im puttin it in a 95 Caprice 9c1. Also, what intake man. and throttle body can i use
Thanks
Old 12-26-2009, 04:01 PM
mcamarols1's Avatar
check the stickys
Old 12-26-2009, 04:41 PM
SOMbitch's Avatar
L92's (LS3) would be my first choice for an OEM head.
243 & 799's off the LS6 & LS2 cars are good too. They are better than 317's if you are not going F/I because you will get a nice compression bump. But any of the genIII castings will "work." I have ported 5.3 (706) castings with bigger valves on my car....
Old 12-26-2009, 08:57 PM
bgoodeno's Avatar
[QUOTE=SOMbitch;12668731]L92's (LS3) would be my first choice for an OEM head.
I concur with the L92. They flow as well as a ported head right out of the box and are relatively cheap.
Old 12-27-2009, 08:26 AM
SOMbitch's Avatar
If go L92's you will have to get a different intake but that is no biggie.......
Old 12-27-2009, 09:35 AM
palaSS's Avatar
Do you mean LS6 or LS3?
Old 12-27-2009, 11:07 AM
SOMbitch's Avatar
First choice would be L76 & second would be the L92 IM from the trucks... LS6 is for cathedrsal ports and won't work...
Heres why>>>>>>>https://ls1tech.com/forums/generatio...omparison.html
Old 01-01-2010, 05:30 PM
LiT1_up's Avatar
The rectangular intake ports on the L92 head also requires the use of an offset rocker arm.
Quick Reply: what Heads fit the LQ4 and LQ9 blocks?
